Climate Control Problem
Old Feb 22, 2003 | 08:21 PM
elnoyl's Avatar
Default Climate Control Problem
On my climate control it's very hard to move the temperature slider. Is my cable bad? What should i do to make it work better?
Old Feb 22, 2003 | 09:11 PM
Chiovnidca's Avatar
Default Re: Climate Control Problem (elnoyl)
Disconect the cable from the hot water valve to see what is tight.
Old Feb 22, 2003 | 09:15 PM
elnoyl's Avatar
Default Re: Climate Control Problem (Chiovnidca)
i did. it didn't seem that hard to push it back and pull it forward. I took the cable completely off and layed it on the ground and it didn't seem to lay flat. i even switched it with a different climate control and re-installed it and it still wasn't right.
Old Feb 22, 2003 | 09:38 PM
Chiovnidca's Avatar
I'm not sure what all you checked. Is the hot water valve free? Is the cable binding? Or is the hot air door sticking?
Old Feb 23, 2003 | 07:33 AM
elnoyl's Avatar
i can open the hot air door with my hands. The cable does seem to have a little tension but i'm not sure what's normal.
Old Feb 23, 2003 | 07:43 AM
Chiovnidca's Avatar
What about the hot water valve?
Old Feb 23, 2003 | 12:56 PM
elnoyl's Avatar
it will open. i just don't know how hard it should be to open and close because i have nothing to compare it with.
Old Feb 23, 2003 | 01:14 PM
Chiovnidca's Avatar
It should be easy to move.
Old Feb 23, 2003 | 03:44 PM
elnoyl's Avatar
your talking about the part that the cable attaches to right?
Old Feb 23, 2003 | 04:36 PM
Chiovnidca's Avatar
Yes, with the heater hoses connected to it.
Old Feb 26, 2003 | 07:50 AM
elnoyl's Avatar
is it supposed to be real easy to move by hand? Should i try to lubricate it? Where should i try to lubricate it at?
Old Feb 26, 2003 | 01:55 PM
Chiovnidca's Avatar
Replace it.
Old Feb 27, 2003 | 11:06 AM
elnoyl's Avatar
isn't that part expensive? Would using some sort of grease or lubricant help?
Old Feb 27, 2003 | 05:13 PM
Chiovnidca's Avatar
It wont hurt to try.
Old Feb 28, 2003 | 09:06 AM
elnoyl's Avatar
how many screws hold it in? Where are the screws located?
1HONDA4U2NV
Oct 13, 2009 12:25 PM
prelude_93vtec
Sep 17, 2008 03:42 AM
DOHCter VTEC
Jan 21, 2008 09:03 PM
hpsi93
Nov 3, 2005 07:34 AM
