climate control problem
hey i have a 97 lude and the control for the blower motor just stopped working. it worked this morning when i went to work, however i was coming home and went to turn on the heat and nothing. is there a fuse or relay? or am i stuck with replacing the blower motor? any ideas guys?
check the diagram on your fusebox to see if there's a fuse. 4th gens have a problem with the solder points on the climate control circuit board, not sure about the 5ths. After i resoldered my pins i got my air vents to work. It's also possible that your blower may be bad. Do you have a helms?
no helms but i think i figured the problem out... i went out today and the blower worked... so it had to be intermittent... so when it stopped working a half hour later i went under the dash and tapped the motor... turned right back on... so im just gonna order another motor and be done with it... thanks for ur response though man
mormonboy
Sep 7, 2007 10:24 PM
Ransom
Jun 25, 2004 03:12 PM
aw1234dude
Oct 31, 2003 08:38 PM
