Check engine light problem
Old Apr 28, 2010 | 04:25 PM
raidacaipo's Avatar
Default Check engine light problem
My friends 99 Prelude keeps getting a check engine light for random misfire of pistons #1 and #2. We changed distributor, cap and rotor, spark plugs, and spark plug wires. Does any one have a clue what could be causing this? thanks
Old Apr 28, 2010 | 05:48 PM
Kronn 98SH's Avatar
Default Re: Check engine light problem
Have you checked the Service Manual?
Old Apr 28, 2010 | 09:10 PM
raidacaipo's Avatar
He doesn't have one.
Old Apr 28, 2010 | 10:15 PM
Kronn 98SH's Avatar
Then get one.
https://honda-tech.com/forums/honda-prelude-4/how-retrieve-cel-atts-abs-4ws-dtcs-2553408/
Old Apr 28, 2010 | 11:00 PM
raidacaipo's Avatar
thanks for the manual download however, Im looking for someone with a quicker response rather then having to read and search for a problem that Im sure is pretty common.
So if anyone else would like to help out just give me your opinion on why we are still getting these codes after resetting the ecu. What could be causing a random misfire for cylinder #1 and #2?
Old Apr 28, 2010 | 11:38 PM
kornkid21792's Avatar
reading is knowledge
Old Apr 29, 2010 | 11:10 AM
Kronn 98SH's Avatar
I gave you the page to start the process. When you turn to that page and find the code, it'll give you another page. You go there and start the troubleshooting procedure. There's no real searching that is required. Just follow the directions.
I understand you believe this to be a common problem, but it's not. No one is going to be able to guess the answer for you. Troubleshooting is the only option.
Old May 12, 2010 | 05:25 AM
Seroga415's Avatar
Post Re: Check engine light problem
*I FIND THIS TO BE THE MOST USEFUL ADVICE, ALWAYS.* THUMBS UP!*
ReubesBB6
Jul 13, 2009 11:51 AM
liger_lude
May 26, 2007 11:57 PM
SilverCivic96
Mar 1, 2007 05:07 PM
merlingt1
Sep 20, 2006 12:54 PM
reVVin
Oct 4, 2001 06:28 AM
