Check Engine Light Help
I just installed my DC Sports Header when the check engine light came on. I am fairly sure it is the O2 sensor that is setting off the light. I was wondering if an OBD-1 h22 cpu would solve this problem. Or what is a wide band O2 sensor and would it help, or could i use some sort of aftermarket computer like the AEM, MoTeC, or TEC3 units. Any help would be great.
You blew your Primary heated O2 sensor. Go buy a new one. Sorry.
It happened to me too, no other way around it, just go shell out the $220.00 for a new one.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 5thGenBen »</TD></TR><TR><TD CLASS="quote">I just installed my DC Sports Header when the check engine light came on. I am fairly sure it is the O2 sensor that is setting off the light. I was wondering if an OBD-1 h22 cpu would solve this problem. Or what is a wide band O2 sensor and would it help, or could i use some sort of aftermarket computer like the AEM, MoTeC, or TEC3 units. Any help would be great.</TD></TR></TABLE>
It is probably your O2 sensor, but you should double check to be sure: http://www.hondaprelude.to/main_checkengine.html
The best solution to your problem would be to fix the problem.
I have a code 45 System Too rich and lean and I am getting approxiamtely 14-15 mpg is this the norm? I am running a greddy turbo kit, bov, fmic, test pipe with a bung to attach the o2 sensor too.
HELP PLEASE
HELP PLEASE
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skhan0501 »</TD></TR><TR><TD CLASS="quote">I have a code 45 System Too rich and lean and I am getting approxiamtely 14-15 mpg is this the norm? I am running a greddy turbo kit, bov, fmic, test pipe with a bung to attach the o2 sensor too.
HELP PLEASE
No, you should not be getting code 45 if the Greddy electronics (which I am assuming you are using) are wired correctly. What year is your lude?
HELP PLEASE
92integraVTECgsr
Jan 21, 2008 07:48 AM
bullet9925
May 29, 2003 05:41 PM
