Check Engine light aftre headers installed?
I just bought dc headers for a sh and had them custom fit to my 94
H22a si and they had to weld on a piece and took out the o2 sensor then they put it back in. Do you guys think i could fix this problem without taking it to the dealership thanks.
Modified by prelude-all-the-way at 12:04 PM 12/31/2006
H22a si and they had to weld on a piece and took out the o2 sensor then they put it back in. Do you guys think i could fix this problem without taking it to the dealership thanks.Modified by prelude-all-the-way at 12:04 PM 12/31/2006
Hmmm...sounds like you put too many headers on. It only needs one.
Jump the service connector and the CEL will flash and tell you what the code is for.
you will have a hard time taking your car to a dealership. They do not normally like to touch any car with any aftermarket parts on it.
The only thing i that would throw a code after a header is installed would have to be something o2 sensor related. Did you make sure you pluged the sensor back up properly and didnt damage it ? Do you have an exhaust leak or anything?
i just saw i was missing a bolt on the header to the far right of it the o2 sensor looks screwed in and the header is welded on to the cat so i dont know how to mess with the computer or any thing like that though thanks
stattonmw
Feb 1, 2006 11:50 PM
skatesalot
15
Oct 17, 2005 12:13 PM
