check engine light
How can I reset the check engine light on my 2001 prelude? I have taken to the dealer twice and both times it is the gas cap. ($80) to have the darn light to be turn off by the dealer!
did you check your codes? if you have a 4th gen, jump the connector behind the radio and check your code. if the problems solved, reset the ecu or jus disconnect the battery
