CEL for oxygen sensor
I have a 5th gen and I just changed both my primary and secondary sensors with new denso ones and after driving for 30 miles I get CEL #67 (Oxygen Sensor Heater (Secondary) malfunctioning or defective oxygen sensor heater) .
I do not understand as to why I am getting this.
I changed the o2 sensors cause both of them were messed up.
Thanks
-Moh
Thanks
-Moh
Did you replace your O2 sensors with heated ones? If you didn't then they might not be getting hot enough to register a voltage and therefore your computer is reading a malfunction. I believe O2 sensors have to be at around 600 degrees to become a semiconductor and read the voltage, so if you are at idle the temp might fall below this number.
Ah, I bought the specific prelude o2 sensors so I am pretty sure they are heated one as you mentioned. I am gonna make sure everything is tight, but I am pretty sure that it already is.
importdreamer
May 26, 2007 06:58 PM
