cel code #9 2nd dizzy what going on?!?!
Old Jun 28, 2008 | 05:10 PM
music462's Avatar
Default cel code #9 2nd dizzy what going on?!?!
its a 93 lude obd1 p13 ecu.. ok so I'm in the middle of doing a swap to a h23a vtec blue top and I keep going threw dizzys..its throwing a code #9 and the people at autozone dont wont to give me another because its the 2nd one..it has bad bogging/skipping can you drive like this?
one more thing when i pull out of the driveway/driving it makes a almost wining sound..I heard my buddys prelude doing this just wanted to know if its normal.. pretty much what can i do about the dizzy can i fix it or argue with autozone for a new one..
Old Jun 28, 2008 | 05:16 PM
worx's Avatar
Default Re: cel code #9 2nd dizzy what going on?!?! (music462)
have u check your timing? check wiring and grounds.
Old Jun 28, 2008 | 05:27 PM
music462's Avatar
yea man timing is dead on we where messing with the timing and stuff to try to make the bogging stop then the cel came on...and my dizzy is all the way advanced is this good??
Old Jun 28, 2008 | 05:36 PM
worx's Avatar
Default Re: (music462)
it should line up to the right markings. use a timing gun, u said u did a headswap right. are your camgears lined up?
Old Jun 28, 2008 | 05:37 PM
music462's Avatar
could the bogging be because i didnt jump the service connector when i set the timing? its the same one to check the cods right?
Old Jun 28, 2008 | 05:39 PM
music462's Avatar
i did a whole motor swap.. all the marks are lined up the up marks and the two lines on the cam grears are goo and the flywheel is deadnuts.. I dont have a timing light I will get one on monday..just one question the flywheel mark is the white one with the "t" right..cause if you spin the crank there is another onr with a groove in it..
Old Jun 28, 2008 | 05:46 PM
music462's Avatar
come people help a lude get on the road after almost 2 months...I'm soo close and its killing me.
Old Jun 28, 2008 | 06:03 PM
music462's Avatar
anyone need expert advice..Oh and the car boggs till like 3k pretty bad does anyone have a vacume and coolant(for the ivac and ficv) diagram I think everything is right but i want to make shure..
Old Jun 28, 2008 | 08:33 PM
playa192's Avatar
just so you know the whining sound is normal
Old Jun 29, 2008 | 07:26 AM
music462's Avatar
can i drive like this or will i do damage?
hondachris1994
May 21, 2015 09:55 PM
2010coupe
Sep 18, 2012 06:13 PM
cgoldman11
Jul 7, 2012 06:37 PM
90civic-ZC
Nov 21, 2011 06:45 PM
