Car Overheating
Old Jun 5, 2006 | 02:05 PM
Wsteun's Avatar
Default Car Overheating
The needle from the temperature gauge almost climbs immediately to about 3/4 of the temperature gauge. When I accelerate quickly, it falls back to around the middle. Also if I put the a/c on full Heat, the needle drops. I popped the hood and noticed that only 1 of the 2 fans on the radiator was spinning, is this the problem? or is it the thermostat?
Old Jun 5, 2006 | 02:13 PM
prelude1897's Avatar
Default Re: Car Overheating (apeng09)
defenitly check your thermostat...It most likely needs to be changed
Old Jun 5, 2006 | 02:14 PM
Wsteun's Avatar
I hope it's something as simple as that. Replacing a thermostat is pretty easy right?
Old Jun 5, 2006 | 02:17 PM
Default Re: (Wsteun)
yeah, it's real easy...You'll need to get some more anit-freeze. It sits on the passanger backside of hte motor. Just follow the big hose that runs from the bottom of your radiator to the back
Old Jun 5, 2006 | 02:20 PM
Wsteun's Avatar
Default Re: (prelude1897)
I don't know if it makes a difference or not, but do the radiator hoses run to the same place on both the base block and the SH block?
Old Jun 5, 2006 | 02:21 PM
yes
Old Jun 5, 2006 | 02:27 PM
Wsteun's Avatar
Thanks a lot, I'll keep you posted. I'm going to be buying a thermostat and replacing it tomorrow night. I've got my fingers crossed...
Old Jun 6, 2006 | 07:23 AM
Wsteun's Avatar
Is the thermostat gasket supposed to be bigger than the thermostat itself?
Old Jun 6, 2006 | 07:33 AM
Yes it is...it'll wrap around your thermostate. Be sure to place it back in correctly, cause it says which side goes upward and there are little groves on the backside of the gasket in which it needs to be placed back in....If anything, use your old thermostat as a reference
Lithel
Nov 3, 2009 08:38 AM
Yellowone
Aug 5, 2008 10:10 PM
JDM_CRX_PLEASE
Feb 1, 2008 03:30 PM
krazyhmongboi
28
Feb 13, 2007 07:58 PM
satintegra
Jul 11, 2002 10:37 PM
