cam install
Old Jul 3, 2001 | 07:19 PM
97BB6's Avatar
New User
Default cam install
Is it true that the head must be pulled to install cams on a H22A?
Old Jul 3, 2001 | 07:37 PM
boomslang's Avatar
Default Re: cam install (97BB6)
Of course not.
Old Jul 3, 2001 | 10:00 PM
mike2016's Avatar
New User
Default Re: cam install (Inlinefour)
you just need to pull the valve cover and disassembly the valvetrain...
Old Jul 4, 2001 | 02:08 PM
G's Avatar
G
Be sure to have a manual, preferrably a helms. That auto tensioner (on 97 and up) can turn a 2 hour job into an entire weekend..... To answer your question, you can replace the cams without removing the head.
[Modified by G, 11:09 PM 7/4/2001]
Old Jul 4, 2001 | 02:49 PM
accordking's Avatar
Default Re: cam install (G)
That auto tensioner CAN be a problem. Make sure you have the tool to clamp the tension in place when you install it back into the motor. You cannot buy the tool from Honda by itself. You have to buy the tensioner with it too.
I spent about $130.00! I forgot it was a long time ago. But doing a whole bunch H22 jobs for people this tool has paid itself off.
Old Jul 4, 2001 | 03:06 PM
migo's Avatar
New User
Default Re: cam install (accordking)
Yes you can buy clamp that locks the tensiner in place, what ever you do DON'T SPILL THE OIL THATS IN THE TENSIONER!
Since you going to install new cams, look into new valve train.
Old Jul 4, 2001 | 03:43 PM
Flavour's Avatar
you may want to consider installing a new autotensioner when you do this. My autotensioner failed at 94000kms and now I'm rebuilding my bottom end.
Old Jul 5, 2001 | 02:25 PM
Honda318dx's Avatar
All H22a motors have a autotensioner, not just 97 up... My 93 has one..
Old Jul 5, 2001 | 02:27 PM
JG Luder's Avatar
Default Re: cam install (Honda318dx)
yup yup.... right you are.
Old Jul 5, 2001 | 03:23 PM
Jarrad_r6's Avatar
New User
My understanding is that it is a good idea to have a line bore done if you are going to put in new cams. In order to do that you would need to pull the head and send it to a machine shop. No line bore, then you can do it without.
Jarrad
Old Jul 5, 2001 | 03:51 PM
G's Avatar
G
Sorry, I only worked on 5th gen's so far.... I made a tensioner tool out of tie wire.... I don't do much work on Prelude motors, so the wire deal helped me out.
hylaxrng
15
Dec 16, 2013 04:54 AM
Christopherian1982
Nov 23, 2008 07:05 PM
import810
Feb 2, 2006 06:55 PM
STP_crx123
Oct 24, 2005 04:41 PM
ramz7887
Apr 15, 2003 05:30 PM
