Bleeding coolant-bleeder bolt
Old Feb 25, 2009 | 04:28 PM
lando griffin's Avatar
Default Bleeding coolant-bleeder bolt
When you are bleeding the coolant using the bleeder bolt- do you loosen the bolt and run the car until there are no bubbles out of the bleeder bolt, with the rad cap on? Or loosen the bleeder bolt with the car off?
This is all the helms show
Old Feb 25, 2009 | 04:35 PM
92civlude's Avatar
Default Re: Bleeding coolant-bleeder bolt
Car OFF. If the car is running with the bleeder loose, it will suck in air!
Old Feb 25, 2009 | 04:57 PM
zsudz922's Avatar
i just take the rad cap off, start the car and let all the bubbles pop out.
Old Feb 25, 2009 | 06:21 PM
gstrudler's Avatar
loosen bleeder bolt before filling rad.
fill rad.
close bleeder bolt when there is a steady stream (no small bubbles).
leave rad cap off and start car.
let car get up to full temp and refill rad as necessary.
turn car off and put rad cap on.
if checking for air in the coolant, loosen bleeder bolt until a steady stream comes out then close the bleeder bolt. remove the radiator cap then start and run the car until it is warm. shut off car and reinstall radiator cap.
Old Feb 25, 2009 | 06:29 PM
SKDRCR's Avatar
No it won't, it will shoot coolant out from the pressure.
Old Feb 25, 2009 | 08:28 PM
92civlude's Avatar
Not if its cold and the t-stat is closed. Rookie Honda techs do it all the time!
kaivorth
Honda Civic (2001 - 2005)
Oct 31, 2016 04:48 AM
lando griffin
Feb 25, 2009 04:34 PM
vtec_crazy
Dec 30, 2004 12:19 PM
delguiner
Apr 28, 2004 11:00 AM
aeon
Jan 1, 2004 05:02 PM
