which is better??
Old May 1, 2003 | 11:27 AM
h2392si's Avatar
Default which is better??
ive heard that the h23 tranny with the h22 swap is no good or not that great. Why is this, does it have something to do with the length of the gears? The reason is that i was getting some quotes for the swap and they told me that if i kept my h23 tranny it yould be like 700 cheaper. I want to do both the tranny and engine but that extra 700 would be a lot less expensive. If anyone has any input on this please help a brotha out. Thanks in advance
Old May 1, 2003 | 11:38 AM
roadawg's Avatar
Default Re: which is better?? (h2392si)
You guessed it, the H23 tranny has longer gear ratios then the H22. You will drop out of vtec when you shift with the H23 tranny. IMO, Spend the extra money and do it right.
Old May 1, 2003 | 01:25 PM
Imprezn's Avatar
Default Re: which is better?? (slownlow)
so the gears are longer when you have to shift at a lower mph?
Old May 1, 2003 | 02:37 PM
Matgallis's Avatar
Default Re: which is better?? (AzNLuder)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AzNLuder &raquo;</TD></TR><TR><TD CLASS="quote">so the gears are longer when you have to shift at a lower mph?</TD></TR></TABLE>
sounds like it
Old May 1, 2003 | 02:59 PM
optikal_blitz's Avatar
what about lowering the vtec engagement point with a vafc? or would it just end up burning more gas being in vtec more often? what do you think?
Old May 1, 2003 | 05:27 PM
PreludeRacer023's Avatar
Default Re: (jz)
you will absolutely be slower with the h23 tranny, it has longer gears, and aside from the vtec problem, the shorter gearing means better acceleration, because every time you shift with the h22 tranny, your landing much higher in the rpm range..if your worried about that money, then use the h23 one, it wont hurt anything, just dont expect to get the times out of your motor...its kinda like using an LS or GSR tranny on a type R...thats one of the big reasons the type R is so quick, it has rediculously short gears..peace
Old May 2, 2003 | 06:42 AM
h2392si's Avatar
Default Re: (PreludeRacer023)
thanks guys, i will defintely save up for the h22 tranny, peace out.
Old May 2, 2003 | 08:29 AM
ludedudesi's Avatar
Default Re: (h2392si)
Actually if you can learn to shift perfectly you will not fall outa vtec. i got it down but now i have a VAFC and i never fall out. might as well use the si tranny while its still good. then later on you can upgrade.
Old May 3, 2003 | 12:02 PM
d98clturbo's Avatar
Default Re: (ludedudesi)
i have an h22 in my acura cl and i am using the stock tranny (same as the accord) which has even longer gears than the h23 tranny...i have never fallen out of vtec when i am racing or running my car hard.....i was able to run a time of 14.7 using the long *** accord gearing and that is with a bone stock motor ...no mods at all..
the longer gears will be good if you do decide to go FI (nos, SC or Turbo)
delslowh23
Jun 26, 2007 01:59 PM
lulu13815
May 6, 2006 12:29 AM
Shane08
Mar 10, 2006 01:26 PM
Beau Gotti
Jun 7, 2005 09:56 AM
