BAD FUEL PUMP???
Old Sep 18, 2003 | 08:05 PM
fe519's Avatar
Default BAD FUEL PUMP???
i tried searching, but cant seem to find a definite question to my answer. well, recently when I try to start it, it starts but dies out. I have to give the puppy some gas by stepping on the pedal a few times to keep it going. But after it idles for a while, the car will run perfectly. Can this be a sign of a bad fuel pump? I changed the relay already and changed the fuel filter, spark plugs, wires, etc... and I cant seem to find the problem. thanks for the help.
Old Sep 18, 2003 | 08:10 PM
fizzbob7's Avatar
Default Re: BAD FUEL PUMP??? (fe519)
could be, but why don't you check the fuel pressure when it's doing that....can you hear it kick on.....not too bad to put the walbro pump in...you could do it in your driveway in an hour if you're halfway knowledgeable
Old Sep 18, 2003 | 09:22 PM
fe519's Avatar
Default Re: BAD FUEL PUMP??? (fizzbob7)
would i have to disconnect the bottom part or top part of the fuel filter to check the pressure?
Pena-bb4-620U.M
Oct 28, 2012 07:17 PM
ewing86
Oct 20, 2004 04:35 PM
mini-v-si
Jun 1, 2004 03:06 PM
shermanyang
Mar 18, 2004 10:47 PM
Z6REX-SI
10
Mar 9, 2004 07:50 AM
