auto to manual conversion
Old Dec 11, 2002 | 04:33 PM
ozzilude's Avatar
Default auto to manual conversion
G'day, I have a 2000 Honda prelude with a tiptronic gearbox and i want to convert it to manual. Is it possible to use a gearbox from another model (e.g. integra type r) or do I have to stick with a prelude gearbox because of the engines rotaion direction?
Old Dec 11, 2002 | 04:37 PM
aklucsarits's Avatar
New User
Default Re: auto to manual conversion (ozzilude)
You need to use an H series gearbox H22A or H23 (or the F22 5spd from the Prelude and Accord would work too).
http://www.geocities.com/mazmotorsports/swap.html
Andrew
[Modified by aklucsarits, 8:39 PM 12/11/2002]
Old Dec 11, 2002 | 05:14 PM
smslude's Avatar
Im not sure in your case but i checked into doing a auto to manual swap in my accord and everyone i talked to told me i was better off just to sell my car and buy a 5sp so thats what i did and i love having a standard they are so much funner to drive.
Old Dec 13, 2002 | 08:38 AM
tightywhitey's Avatar
Old Dec 13, 2002 | 10:48 AM
DarkJedi's Avatar
Default Re: auto to manual conversion (tightywhitey)
why not upgrade to a jdm tranny w/ lsd while ure at it
Old Dec 13, 2002 | 10:53 AM
Champ R's Avatar
Default Re: auto to manual conversion (DarkJedi)
Auto to manual swaps are a royal pain in the ***. Its going to end up costing a decent amount, plus most likely wont be solid as an original 5spd lude. Id consider just selling your car and getting a manual version to save the hassle.
Old Dec 13, 2002 | 12:56 PM
zameoj's Avatar
Default Re: auto to manual conversion (Champ R)
Hi. Thats my swap page you have listed above. I'm glad you are using it and I hope it proves helpful to some people. Its still a rough draft so don't mind the errors. The swap was the cheapest way out for me, but everyones situation is different.
On a side note:
I had to re-register. Not sure what happened. Maybe its because I hadn't posted in a while.
[Modified by zameoj, 9:57 PM 12/13/2002]
Old Dec 13, 2002 | 11:36 PM
ViZ's Avatar
ViZ
Default Re: auto to manual conversion (zameoj)
b series swaps are easy h and f are a pain because you have to weld the plate on in the interior total cost of swap without labor can range from 3-5 even 6 hundred then labor is going to be pretty bad thats where most of the money will go unless you do it your self
Old Dec 14, 2002 | 07:50 AM
zameoj's Avatar
Default Re: auto to manual conversion (ViZ)
I didn't need to weld the plate in. I reinforced the firewall instead. Its worked well so far. No flex at all. $600 for parts??Show me where..A H22A tranny swap is not going to cost 3-6 hundred and don't forget all the extra stuff you need. You should be looking in the $1000 to $2000 range for all the parts. Labor shouldn't take more than 8 to 10 hours for a skilled tech with the proper info (including the necessary wiring). To get an 5th Gen Prelude auto tranny rebuilt (properly) will cost just as much or more. Then you risk it breaking again.
ViS--very good web design stuff. I wish I could do stuff like that.
[Modified by zameoj, 9:54 PM 12/14/2002]
Old Dec 14, 2002 | 09:07 AM
kotetu's Avatar
I went to the dealer and asked for my manuals and stuff (I bought my auto from the dealer) It turned out they had all the spare keys and stuff in a manila envelope and gave them to me with the manuals.
You should call and ask.
Old Dec 14, 2002 | 11:03 AM
New User
Yeah, I saw your post on http://www.Preludeonline.com about the swap page you made. Sorry, I should have given you credit... Your write up so far is execellent!
Andrew
Jlm_93accordlx
Aug 22, 2017 10:24 AM
y-49
Nov 2, 2006 06:35 PM
ukvtec
Aug 20, 2004 08:19 PM
hondaACCORD
Apr 10, 2004 11:29 AM
