audio problem on 5th gen
Old Dec 4, 2004 | 06:14 AM
bchomka's Avatar
Default audio problem on 5th gen
im replacing my stock speakers on my 5th gen lude with aftermarket ones, and i took the speaker out and there is an adapter connected to the wires that would fit the stock ones but will not fit the kenwoods i bought. i figured i could just cut hte connector and solder it on buy there are 4 wires. (are there just 2 positives and 2 negatives). Or is there some kind of adapter it could connect the the stock adapter to fit the new speakers.
i need help
Old Dec 4, 2004 | 09:57 AM
ItalynStylion's Avatar
Default Re: audio problem on 5th gen (bchomka)
The reason there is more than 2 wires is because of the acoustic feedback system. You just need to go through and test the wires, two have power running to them the other two i just cut and taped off. Im not sure about the colors of the wires though, maybe someone else can help with that. Also, your talking about the front speakers right?
Old Dec 4, 2004 | 05:25 PM
prylwd's Avatar
I dont understand what ItalynStylion said why would you find the the two wires with power and use both. Doesn't the negative post of the speaker go to a wire that doesn't have power.
Old Dec 4, 2004 | 05:49 PM
Default Re: (prylwd)
Your right i worded that wrong, only one has power. But what i meant to say is only 2 of the 4 wires make the speaker work and you need to test them to figure out which ones they are. Sorry about the confusion
twiztid00002
Aug 24, 2008 10:57 AM
JDMSi92
Audio / Security / Video
Jun 13, 2005 08:37 PM
imadigitalgod
11
Oct 30, 2004 12:32 PM
jdmcrx1
Oct 14, 2004 10:14 AM
