Any A/C gurus?
Old Jul 27, 2001 | 01:58 PM
JG Luder's Avatar
Default Any A/C gurus?
OK, here's the low down:
4th gen w/ H22A1
I have regular A/C, and no pullies. Belts are stock sizes.
My AC clutch thing (whatever you call it) fell off. It's the 5" or so circular plate w/ 3 big *** rivets in it that sits on the outside of the A/C compressor belt pulley.
Yessir... it fell right off. I haven't had a chance to look at it, or he compressor, but I was wondering if anyone here has fooled with that ish yet?
OK, what should I look for as far as:
-Damage?
-What will I need to replace?
-Can I shove this clutch back on it if it's not too bad?
-Will I need any special bolts?
-What size?
Any, or all, of the info above would be greatly appreciated. If I don't think I can do it, then it goes to my mechanics, but (no offense to Don) I can't afford that mess right now, I'm still trying to get tires, and have my cams FIXED.
Muchas Gracias Senors...
-JG
Old Aug 1, 2001 | 03:48 PM
G's Avatar
G
Default Re: Any A/C gurus? (JGLuder)
Sorry, I've been computerless for a few days. My integs compressor pulley had a 10mm bolt holding it in, but the magnetism pulls and locks it when the AC clutch is engaged. If the steel (I assume it is similar to the integ's) outer pulley isn't cracked or deformed, it should be just fine. Mine fell off @ 50mph and I ran it over with only a few scratches, no deformity and works just fine....HTH
Crobran
Feb 10, 2017 07:55 AM
Crobran
Jan 28, 2017 06:15 AM
red ej
Jul 27, 2009 07:42 PM
boostlude
Oct 19, 2005 02:00 PM
