act clutch not fitting flush with flywheel? is this normal?
Old Sep 12, 2003 | 12:04 PM
luderone's Avatar
Default act clutch not fitting flush with flywheel? is this normal?
heres the the deal I have a 92 prelude, swapping in a h23, installing act clutch xs pressure plate, and a 6 puck disc, now when I have the disc and Pressure plate on the flywheel the pressure plate doesn't fit flush on the flywheel. it sticks about 1/4 inch off the flywheel, maybe less. all the bolt holes and pins match up. if I tighten down the pressure plate won't that be to much force on the disc. and keep it engaged? or is this normal? I hate like hell to bolt every thing together find out its wrong and have to rip it back down. thanks Ray
Old Sep 12, 2003 | 12:33 PM
Sephro's Avatar
Default Re: act clutch not fitting flush with flywheel? is this normal? (luderone)
I am a little confused what you mean here.
Are you saying that the pressure plate does not mate up flush with the flywheel?
Or when the pressure plate is mated up with the flywheel there is a gap between the pucks and the flywheel?
Old Sep 12, 2003 | 12:48 PM
2point6's Avatar
Default Re: act clutch not fitting flush with flywheel? is this normal? (Sephro)
turn the disk around.
Old Sep 12, 2003 | 01:04 PM
Greyout's Avatar
Default Re: act clutch not fitting flush with flywheel? is this normal? (2point6)
haha
Old Sep 12, 2003 | 01:35 PM
machine4321's Avatar
well do you have the PP bolted down????
if not then it will sit up abit .....as you bolt it down the clutch is under pressure......whitch is how its supposed to be
Old Sep 13, 2003 | 08:56 AM
luderone's Avatar
Default Re: (machine4321)
thanks machine4321, thats all I needed to know.
Old Sep 13, 2003 | 02:01 PM
BoostedH23a1's Avatar
Default Re: (luderone)
he beat me to it.. the fingers will tigten up
dtme46
Mar 7, 2009 11:07 PM
95_red_dc
Transmission & Drivetrain
Sep 5, 2008 02:38 AM
95_red_dc
Sep 2, 2008 06:19 PM
methanemotorworks
Feb 13, 2006 07:32 PM
boosted350z
Nov 27, 2004 06:49 AM
