Accessing rear shocks from trunk
Old Feb 28, 2007 | 07:43 AM
vinuneuro's Avatar
Default Accessing rear shocks from trunk
I need to replace the shock collars because of shock knock. How easily is it to remove the top hat, etc by gaining access through the trunk?
Old Feb 28, 2007 | 07:51 AM
Chuckles99SH's Avatar
Default Re: Accessing rear shocks from trunk (vinuneuro)
Just go ahead and cut all that sheet metal away from inside your trunk to get to those top hats and let us all know how it goes..
You can unbolt your tophat from inside the trunk, a few bolts and it should come out from the bottom.
Old Feb 28, 2007 | 07:53 AM
prelude_h22vtec's Avatar
lol this guy^^^
you unbolt the shock at the bottom, undo the nuts in the trunk and the shock and spring comes out.
Old Feb 28, 2007 | 08:30 AM
vinuneuro's Avatar
Default Re: (prelude_h22vtec)
I was hoping to do this without removing the shocks..hmm
Old Feb 28, 2007 | 09:25 AM
godslayer's Avatar
Default Re: (vinuneuro)
FAQ
Read it. I did and it took me all of 10 minutes to change the collars.
Old Feb 28, 2007 | 09:29 AM
vinuneuro's Avatar
Default Re: (godslayer)
I must've missed it. Where in the faq is this?
Old Feb 28, 2007 | 10:21 AM
Jagan'92's Avatar
uh i must be blind also, i can't find it
Old Feb 28, 2007 | 12:45 PM
vinuneuro's Avatar
Default Re: (Jagan'92)
I think he was just trying to be a *****...w/e. If anyone knows how to change the collar without removing the strut assembly in the rear, please post.
Old Feb 28, 2007 | 04:01 PM
jdmlude5
Guest
Posts: n/a
well if it is a 4th gen u need to remove the back seats.. the second bolt is behind the top half of your back seats..
Old Feb 28, 2007 | 09:37 PM
M@'s Avatar
M@
Default Re: Accessing rear shocks from trunk (jdmlude5)
w/o looking at anything and not messing w/ my shocks for a year this is how I THINK you do it.
First you pull the interior panels. Then unscrew the nut on the very top of the shock. Remove the washer, and you maybe able to remove the collar from there. You may need to remove the rubber bushing to get at the collar.
DO NOT DO THIS WITH THE CAR JACKED UP!
Just leave it on the ground.
Also look it up before you just take my word, but it won't hurt to try it if you are lazy. Just don't try it with the car in the air.
Slade
Sep 17, 2011 08:40 AM
vinuneuro
Suspension & Brakes
Mar 1, 2007 10:05 AM
civicEXtreme
Feb 19, 2006 06:52 PM
ANGELIQUE
12
Apr 28, 2004 10:08 AM
SD_EM1
Jul 16, 2003 04:42 AM
