ABS Light On???
Old Jan 28, 2003 | 10:05 AM
Brett-Pac's Avatar
Default ABS Light On???
Hey Whats up guys, Im new to the Board, but Ive had my 92' Prelude for about a year and just dropped and H22 in it about 3 months ago. Running great...Thank God. But my question is, I was driving the other day and i went to slow down and my ABS dash light came, I thought it was odd and maybe just a fuse. Changed out the Fuse and it went out. Next day...It did it again. Anyone have any suggestions?
Old Jan 28, 2003 | 10:58 AM
rjr162's Avatar
Default Re: ABS Light On??? (Brett-Pac)
you should be able to jumper the dianostic plug and the ABS lgiht will flash just like the CEL light. Cross-reference and it should hold your answer
>> This atleast holds true for the 5th gen, and even if you erase the ECU's memory, it still seems to retain the ABS info
[Modified by rjr162, 7:58 PM 1/28/2003]
Old Jan 30, 2003 | 06:44 PM
H23vtecEG's Avatar
one of your abs sensors went bad. have you pulled on any of the wires?
Old Feb 1, 2003 | 06:27 PM
dpreludesi's Avatar
Default Re: ABS Light On??? (H23vtecEG)
If your brake light is on (right under the abs light) it will set it off. After a certain amount of time of the brake light being on, the abs light will turn on. Try checking the e brake wire and see if it is grounding itself.
Old Feb 1, 2003 | 07:00 PM
rjr162's Avatar
Not true, it could be the ABS relay, or the whole control unit its self (which is what went in my place, and I wasn't going to pay $800 for something I don't care for anyhow.. atleast not in the snow)
Old Feb 2, 2003 | 07:55 AM
papa_smurf's Avatar
Default Re: ABS Light On??? (rjr162)
man this happened to me too, i went to honda and they wanted something like $1200 to fix it, they concluded that the whole ABS moduoule was shot, F#@K that ****. but anyway the real bitch of it was that i bought a new ABS module and was planning on when i would have time to install it and the damn light went out, and never came back on. ABS works perfectly and everything. that was about a year ago now. anyway if you need a ABS module i have a spare one i will well to ya
Old Feb 2, 2003 | 08:00 AM
Jonesy69's Avatar
Default Re: ABS Light On??? (papa_smurf)
I have the same problem, but my light wont turn on untill it sounds like something is done cycling. It sounds like a small pump, or electric motor, and it comes from under the passenger side dash. Everytime I start the car, it starts, then I hear the pump (or whatever it is) begin to cycle, it cycles for about 5-10 seconds then stops, at which point the ABS light comes on.
Anybody have any insight to offer me?
Old Feb 2, 2003 | 11:20 AM
Ponce3212's Avatar
I have the same problem but i drive an Accord and the ABS light doesn't come on until go over 85-90 mph. Dont know what the problem is..
Old Feb 2, 2003 | 12:03 PM
rjr162's Avatar
Default Re: ABS Light On??? (Ponce3212)
mine will come on, but only rarely, and then go off when i restart it
laurn
Suspension & Brakes
Feb 18, 2013 07:30 AM
RotaryPWR
Aug 12, 2009 11:36 AM
94coupeNA
Jan 26, 2006 12:56 PM
redteg1
Aug 18, 2001 02:42 PM
