Abs light
yea i changed both axles and the both had the funky ribbed ring on them. I put everything back as i saw it. im just stumed why my light is going on. were are the sensors for the abs, are they close to the ring thing on the axles?
My ABS light has come on a few times, the code showed my wheel-speed sensor was faulty. I changed it, then a month later it came back on and it's another wheel-speed sensor, I'm assuming another one, didn't bother changing it yet seeing the cars torn apart in the garage.
From what I've seen, 4th gen Preludes and ABS lights are VERY common!
Pull the code and see what it says.
Just get to the blue connector and jump the connector and the ABS light will flash a code.
Here is the list for the codes. It usually does a series of quick flashes, a pause, and then another series of quick flashes.
Codes:
1 - ABS pump motor over-run
1 2 ABS pump motor
1 3 high pressure leakage
1 4 pressure switch
1 8 high pressure system
2 1 parking brake
3 1 pulser RF
3 2 pulser LF
3 4 pulser RR
3 8 pulser LR
3 12 different diameter tires
4 1 wheel sensor RF
4 2 wheel sensor LF
4 4 wheel sensor RR
4 8 wheel sensor LR
5 - rear wheel lock - R/L
5 4 rear wheel lock - R
5 8 rear wheel lock - L
6 - fail-safe relay - F/R
6 1 fail-safe relay - F
6 4 fail-safe relay - R
7 1 solenoid - RF
7 2 solenoid - LF
7 4 solenoid - R
8 1 ABS function
8 2 CPU comparison
8 4 IC self-check
Codes:
1 2 ABS pump motor
1 4 pressure switch
2 1 parking brake
3 1 pulser RF
3 2 pulser LF
3 4 pulser RR
3 8 pulser LR
4 1 wheel sensor RF
4 2 wheel sensor LF
4 4 wheel sensor RR
4 8 wheel sensor LR
7 1 solenoid - RF
7 2 solenoid - LF
7 4 solenoid - R
8 1 ABS function
8 2 CPU comparison
8 4 IC self-check
Codes:
1 2 ABS pump motor
1 4 pressure switch
2 1 parking brake
3 1 pulser RF
3 2 pulser LF
3 4 pulser RR
3 8 pulser LR
4 1 wheel sensor RF
4 2 wheel sensor LF
4 4 wheel sensor RR
4 8 wheel sensor LR
7 1 solenoid - RF
7 2 solenoid - LF
7 4 solenoid - R
8 1 ABS function
8 2 CPU comparison
8 4 IC self-check
Codes:
1 2 ABS pump motor
1 4 pressure switch
2 1 parking brake
3 1 pulser RF
3 2 pulser LF
3 4 pulser RR
3 8 pulser LR
4 1 wheel sensor RF
4 2 wheel sensor LF
4 4 wheel sensor RR
4 8 wheel sensor LR
7 1 solenoid - RF
7 2 solenoid - LF
7 4 solenoid - R
8 1 ABS function
8 2 CPU comparison
8 4 IC self-check
help me out here a little, i got abs problem too, abs light went on 8 times and check engine 4 times when i tried to pull the code, ill doble check tommorow, but abs light went on 8 blinks for sure.
Russlan, did it blink 4 times, have a little pause, and blink another 4 times? If so, it's your right rear speed sensor (I have same problem).
Double check again, it should blink, have a pause, and blink again
yeah i just checked again and it was 4 pause then 4 again? where is that right rear speed sensor? is it abs sensor?
siblue_gzer
Aug 13, 2007 12:17 PM
