ABS code for 96 Prelude Si
Old Dec 25, 2010 | 05:23 PM
iponnet's Avatar
Default ABS code for 96 Prelude Si
my abs light came on today so I connected a jumper to the service connector underneath the dash and turned the key on. after the light came on and went off after two seconds I got one blink pause for about 5 seconds and I got another single blink!! what code number is this? is this two separate codes or is this code 11?
any advice or help appreciated,
Old Dec 25, 2010 | 05:54 PM
Kronn 98SH's Avatar
Default Re: ABS code for 96 Prelude Si
The codes repeat. You have one code of 1. Look it up in the manual.
Old Dec 25, 2010 | 06:59 PM
dbd6604's Avatar
I believe that is ABS pump overrun. I'm pretty sure, but my Helms is in the garage and it's snowy out so...
Old Dec 27, 2010 | 08:06 AM
iponnet's Avatar
tx for the replies, I was hoping it wasnt the pump... anyways I also have a srs light on, according to my research online the same connector that I jumped to get the code for the abs should get the srs light to blink a code too!! but it simply stays on, do I need to fix the abs problem first or am I doing something wrong?
thanks again
92exaccord
Dec 23, 2007 08:55 PM
prelude_93vtec
Jun 28, 2007 02:58 PM
arren123
Jun 18, 2007 04:00 AM
94ls
Sep 2, 2004 06:29 AM
VTECAcuraGSR
Aug 18, 2002 03:33 PM
