92 Prelude Electrical Problems
Old Jun 14, 2011 | 01:43 AM
anewman1234's Avatar
Default 92 Prelude Electrical Problems
I searched everywhere and couldn't find anything specific that matched my problem, so forgive this post if it already exists as I will have to forgive myself for what I've done to my car -
Jumper cables, low light, beer..backwards. Blew the battery fuse, I replaced it. Jumped it off again and it cranked right up like nothing had happened. I go to put it in reverse, (automatic trans.) and it dies as soon as I shift gears. And there's no more power to anything while the key is on but when i turn the key to the off position the radio turns on? Wierd. The new battery fuse is still good by the way. I know I fried something and really need someone to point me in the right direction of where to start checking.
Old Jun 14, 2011 | 05:57 AM
1GPlusSH's Avatar
Default Re: 92 Prelude Electrical Problems
maybe you melted some wires together...you probably need the honda place to check this one out.
Old Jun 14, 2011 | 09:10 AM
if there's power to the radio when the key is off then couldn't I remove the ignition switch, hot wire it to start, and if the problem lies in the ignition switch everything should work just fine, correct?
Old Jun 14, 2011 | 07:10 PM
1GPlusSH's Avatar
maybe, but i would try to fix the problem.
mushroomyz08
Dec 23, 2015 01:47 PM
oioioimike
Mar 28, 2008 05:33 PM
djbrandonr
Mar 23, 2007 06:49 PM
strils
Jan 11, 2007 08:06 PM
shutta
Aug 27, 2006 12:42 PM
