5th Gen Lude performance problems.
Old Apr 5, 2006 | 04:34 AM
mcandmar's Avatar
Default 5th Gen Lude performance problems.
I've been asked to look at the car for a friend of mine, its a late european 2.2 vtec.
Engine runs ok when cold, after it warms up it starts to hesitate and jump on part throttle. Performance is terrible, goes ok above 5000rpms but everwhere else its gutless and un responsive. Felt like a car running with a big air leak but i cant find anything.
Car has been serviced, and a new O2 sensor has been fittted. No ECU check light, but i'm not sure if it is possible there could be error codes without it lighting the dash light? Can i check it with the same procedure as a 4th gen with a paper clip in the diag connector?
Any other advice or ideas would be great as i'm scratching my head on this one...
Thanks,
Mark.
Old Apr 5, 2006 | 06:31 AM
The Weather Man's Avatar
sounds like limp mode to me......
Make sure you're getting good fuel.
Old Apr 5, 2006 | 06:58 AM
mcandmar's Avatar
Default Re: 5th Gen Lude performance problems. (mcandmar)
When the car runs in limp home mode will it light up the check engine light?
It does seem like that is the problem but i dont know how to tell if you know what i mean?
Old Apr 5, 2006 | 07:24 AM
four o two's Avatar
Default Re: (The Weather Man)
Why would a car in limp mode run like **** below 5000 rpm, but run fine above 5000 rpm?
Old Apr 5, 2006 | 07:54 AM
98vtec's Avatar
moderator emeritus
Default Re: (four o two)
fuel injector cleaner, cap and rotor, plugs, wires, fuel filter.....all the necessary tune up items. Might even want to seafoam the motor.
Old Apr 6, 2006 | 12:46 AM
mcandmar's Avatar
Default Re: (98vtec)
Seafoam?
krott5333
May 6, 2004 06:08 PM
BlckBeautyVTEC
Apr 14, 2004 12:35 PM
Revi
Jan 13, 2004 07:27 PM
barnetz
Mar 27, 2003 11:59 AM
jared703
Oct 15, 2001 09:41 AM
