4th gear problem
Old May 24, 2003 | 10:17 PM
WNYAccordLX's Avatar
Default 4th gear problem
Well, 1,2,3,5,R Shift fine but I have no 4th. Doesnt grind, just doesnt move into gear. Its like its siezed up. It all started when I couldnt get it in 3rd a while back so I just played with the cables and added a little more fluid and now I have absolutley no 4th and 3 works well. Any suggestions?
Old May 25, 2003 | 04:58 AM
Sticky Tires's Avatar
* B A N N E D *
Default Re: 4th gear problem (WNYAccordLX)
bad syncro? or maybe you need a new clutch.
Old May 26, 2003 | 11:57 AM
flyrod's Avatar
It doesn't go in with the engine running, or while driving, or doesn't go in at all? Sounds like something wrong inside the tranny. 3rd and 4th are on the same shift fork inside the tranny. If that fork is bent, that could explain why adjusting the cables moved the problem. If you can eliminate the shift cables as a possible problem, then I'd say you have to open the tranny.
BULL3TPR00F
Feb 14, 2012 10:00 PM
98bucket
Sep 17, 2008 10:09 AM
preludesi2188
Nov 28, 2005 07:08 AM
5litereater
Aug 4, 2004 10:05 PM
thugfolife2
12
May 3, 2004 05:42 PM
