4 wire o2 sensor help!!!!!!!!!!!!!!!
Old Feb 27, 2004 | 06:43 PM
  #26
H22A EG6's Avatar
Default Re: 4 wire o2 sensor help!!!!!!!!!!!!!!! (H22A EG6)
i think it is giving me a 36 but it is kinda late i will check tomarro
i cant belive it finally worked you the man C dogg
Old Feb 27, 2004 | 11:50 PM
  #27
H22A EG6's Avatar
https://honda-tech.com/zerothread?id=151825
i got the same prob
Old Feb 28, 2004 | 03:05 PM
  #28
2.2L EH2's Avatar
i didn't read all the post on your thread. but heres the o2 sensor wiring info:
white- yellow'black (A25 power source)
white orange/black (A6 heater control)
black- green/white (D22 sensor ground)
gray- white (D14 input)
the o2 sensor i used for mine was a denso unverisal o2 sensor.
Old Feb 28, 2004 | 03:42 PM
  #29
H22A EG6's Avatar
Default Re: 4 wire o2 sensor help!!!!!!!!!!!!!!! (BOUNTY_HUNTER)
cool
will check that out<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BOUNTY_HUNTER &raquo;</TD></TR><TR><TD CLASS="quote">i didn't read all the post on your thread. but heres the o2 sensor wiring info:
the o2 sensor i used for mine was a denso unverisal o2 sensor. </TD></TR></TABLE>
ok so the codes i am throwing are
36-4ws "gost" code
7-throttle position sensor
5-manifold absolute pressure sensor
41-Primary oxygen sensor heater
ok so i have a civic so i dont care about 36
7-well i have no intake on there other than that does any one know what to check other than the wires on the TPS?
5- i have no idea what to do for this. i thought this was only a problem with turbos
althought the exhaust is not hooked up. could that be a problem?
41- the O2 needs to be rewired prob.
if any body know what to do for these i will be very fgreatfull for your help!
Old Feb 28, 2004 | 03:44 PM
  #30
H22A EG6's Avatar
looking at this the only one that i think could cause this prob would be the #5 code
Old Feb 28, 2004 | 04:12 PM
  #31
mattmw88's Avatar
Default Re: 4 wire o2 sensor help!!!!!!!!!!!!!!! (93ludeSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93ludeSi &raquo;</TD></TR><TR><TD CLASS="quote">the o2 sensor works on 1/2 volt of electricity, any lack of quality in the connection and cause a varience in signal great enough to make the car run poorly</TD></TR></TABLE>
Is this true for the female side of the engine harness? In other words if my engine harness right before the O2 female connecter is cut, could it change the frequency? I have tried replacing the sensor with an OEM and no improvement. I was going to buy another OEM sensor and try it after I install my new 370cc injectors and have everything tuned. Does that sound like a smart idea? Thanks for your help!
Old Feb 28, 2004 | 04:18 PM
  #32
H22A EG6's Avatar
Default Re: 4 wire o2 sensor help!!!!!!!!!!!!!!! (mattmw88)
well i am gonna make a new post for the codes this title is not working to my advantage
:mR. PotAtO heaD:
Oct 8, 2007 08:55 PM
DSRxSALSA
Dec 16, 2005 06:23 PM
Driven
11
Aug 30, 2004 08:35 PM
TurboJesse
Oct 20, 2003 02:44 PM
