4 wire o2 sensor help!!!!!!!!!!!!!!!
so i got a new sensor and now my car idles like ****! and revs like carp.
i have not started my car in 6 months could this be the reason
also i just put the tranny back on
i think i wired it up wrong on the new sensor it has 4 wires but the are differen colors!!!
black, grey, and two white
org has black, black, white, and green
witch hooks up with what
thx
thx
well my car still runs like ****
when i unplug the sensor it still acts the same
so i still think it is fucked up
any one else wanna give it a shot?
or other possible trouble shooters
this is driving me nutz out of the year i have had the car i have only had it on the road legally for 2 weeks!!!!!!!!!
AHHHHHHHHHHHHHHHHHHHHHHHHHHH
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H22A EG6 »</TD></TR><TR><TD CLASS="quote">so i got a new sensor and now my car idles like ****! and revs like carp.
Is it a stock or aftermarket sensor? Throwing any codes?
it is a Borg Warner sensor and the check engine ligh is on
i cant check it thought i dont have the green plug thing
seriously get an oem, or a direct fit replacment. It sounds like you are using the one that you wire into the honda harness. This is NO GOOD, the o2 sensor works on 1/2 volt of electricity, any lack of quality in the connection and cause a varience in signal great enough to make the car run poorly
u should check the code and stop guessing, considering you haven't run your car in 6 months, anything could happen in that amount of time.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by homesauce »</TD></TR><TR><TD CLASS="quote">u should check the code and stop guessing, considering you haven't run your car in 6 months, anything could happen in that amount of time.</TD></TR></TABLE>
Yea, i was trying to help him with that. He's has some difficulties.
i am starting to think i might be the timing
when my friend and i installed a new motor in his bug the timing was way off my car is kinda running like that
what do you guys think
but i did not touch the motor so i dont know how the timing would be off. any possible explanations for this?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93ludeSi »</TD></TR><TR><TD CLASS="quote">seriously get an oem, or a direct fit replacment. It sounds like you are using the one that you wire into the honda harness. This is NO GOOD, the o2 sensor works on 1/2 volt of electricity, any lack of quality in the connection and cause a varience in signal great enough to make the car run poorly</TD></TR></TABLE>
i completly sodered the wires together
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H22A EG6 »</TD></TR><TR><TD CLASS="quote">i am starting to think i might be the timing
but i did not touch the motor so i dont know how the timing would be off. any possible explanations for this?</TD></TR></TABLE>
Less posting, more checking of codes . . . .
Sorry, but the OEM sensors are a complete rip-off . . . . The $60 universals are the exact same thing, just take a tiny amount of care when you're wiring it up.
Besides, when you first start the car up, it's not looking at the sensor - it's in open-loop operation. The symptoms remaining with the sensor removed supports this. So something else is going on - poor timing (either cam or ignition) could easily cause it, but check the code first and go from there.
yea i ran out of thime on sunday and going to check codes and timing first thing on fri you guys are the bestest
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Daemione »</TD></TR><TR><TD CLASS="quote">
Besides, when you first start the car up, it's not looking at the sensor - it's in open-loop operation. The symptoms remaining with the sensor removed supports this. So something else is going on - poor timing (either cam or ignition) could easily cause it, but check the code first and go from there.</TD></TR></TABLE>
This is very true, if it is running poor at a cold start you most likely have another problem, could be a vaccum leak in the intake mani, check to make sure that a line didn't get cut during install
ok
here is the scoop the ******* wires dont ******* match scence i dont have a service plug i used this digram to make my own with the help of Chiovnidca
\i connected the d4 wir3 to the d17 and i got javk ****!
the ******* colors dont even match!
wtf am i gonna do now i am going nutz!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H22A EG6 »</TD></TR><TR><TD CLASS="quote">ok
wtf am i gonna do now i am going nutz!</TD></TR></TABLE>
"93" civic, right? The wire color at pin D4 should be brown. Just backprobe that pin with a paperclip or something and connect the other end to ground.
