4 Distributors and still same problem.
Old Sep 17, 2013 | 03:13 PM
AudioFunk's Avatar
Default 4 Distributors and still same problem.
My car didn't start so I had a mechanic do a compression check. I was at work, but he said he did. He said compression was fine and he recommended me to change the dizzy. As he was taking the wires off he was struggling. He didn't know you had to take off the clip that the wires hold on too. I wonder now if he didn't even unhook the dizzy and he might of done some damage to the coil? My symptoms is a bouncy tach followed by the car stalling. Put on a new dizzy that made my car run good for a few hours then the tach started to bounce. It bounced like that for a few days without the car stalling or shutting off. I got a new dizzy, yes brand new from buyautoparts. And put it on. Still, same symptoms. Put on the old one that had the bouncy tach but the car didn't stall and this time it stalled? Went back to autozone and got a replacement and same thing. It's driving me nuts. I'm starting to think It's not the dizzy. What are the odds on 4 distributors being faulty. I can't afford a new car right now and I need this car to get to work. So in the meantime I need to get this fixed. Does this sound like a coil? Thanks guys
Old Sep 17, 2013 | 03:47 PM
thundernoodle's Avatar
Default Re: 4 Distributors and still same problem.
clearly not a dizzy. you need to look elsewhere
Old Sep 17, 2013 | 09:09 PM
motoxxxman's Avatar
sounds like a bad ground. clean and tighten all of the grounds in the engine bay; the battery, vc and/or IM, and harness ground on or near the water outlet.
Old Sep 17, 2013 | 11:38 PM
holmesnmanny's Avatar
perhaps your wire(s) are bad
Old Sep 18, 2013 | 08:58 AM
Bouckaroo's Avatar
I would be cxhecking plugs, wires and rotor.
When you replaced the dizzy did you replace all the components? I know that once on my gf old integra we bought a cheap canadian tire brand distributor and it caused allsorts of issues; we ended up buyying the oem unit form acura and repalced the wires and pugs and presto issue resolved.
We had stalling issues at mid rpm, high rpm misfires, hard hard cold starts, and random shut downs.
Old Sep 18, 2013 | 11:18 AM
AudioFunk's Avatar
I got new plugs, wires, cap, and rotor. I put on a oem re-manufactured one and it seemed to solve it for a day and then the tach started to bounce again
Old Sep 18, 2013 | 12:00 PM
AudioFunk's Avatar
I was going to work and when I went and started my car it started but it didn't last long. It would stall in like 10 sec or 1 min. I got a new dizzy the next day, put it on and it seemed to fix the problem. Later that day around 10 PM I was coming home and the tach bounced. Over the next 3 days the tach would just bounce all over the place but my car didn't stall until 2 days ago it seemed to want to stall so I got a new dizzy before it left me stranded. I put this dizzy on and turned on the car and the tach needle still bounced and the car stalled. I put on the old one because it never stalled but this time it did. I'm starting to think It's not the distributor. Can a bad coil cause this?
Old Sep 18, 2013 | 12:38 PM
AudioFunk's Avatar
Guys, I got closer to the problem. While the key was turned on the D4 light or CEL didn't come on. So I went to my engine bay and heard a crackling noise. I moved the main ground on the thermostat housing and boom I would hear fuel pressure. That ground is bad or dirty. It explains my ECU not getting power since It's clearly not being grounded correctly. How can I clean it?
Old Sep 18, 2013 | 01:40 PM
AudioFunk's Avatar
Problem solved. It was the main ground under the thermostat housing. It wasn't tight. Cleaned it a bit and tightened it up and boom, no more bouncing tach and D4 and CEL light up every-time now.
Old Sep 18, 2013 | 07:46 PM
motoxxxman's Avatar
sandpaper is the best ground cleaner, followed by simply wiping with a clean rag.
Old Sep 18, 2013 | 09:14 PM
AudioFunk's Avatar
You sir are the man
twentyhurtz
Dec 7, 2006 05:16 PM
crxh22project
13
May 14, 2005 02:03 PM
sauchi55
Mar 15, 2004 08:12 PM
