2.??? Prelude
Old Feb 25, 2003 | 01:36 PM
myh22's Avatar
Default 2.??? Prelude
hey crew, got a fairly straight forward question. what is teh biggest possible size that i could get my engine to? 2.2 to a 2.4 unreasonable? if not, then how is it done, and what have those of you who have it noticed. more horses??? what, and who did you go through for a 2.4 bore. i want to go N/A but im affraid i wont reach my goal with a 2.2. when all is said and done, i wanna see a minimum of 300 horses. of course that is with 11:1 piston heads, every conceivable bolt on, ecu upgrade, and electronic gadget that i can get my hands on. thanks in advance fella's.
Old Feb 25, 2003 | 01:54 PM
Mikey3000's Avatar
Default Re: 2.??? Prelude (myh22)
300 horsepower at the wheel is unreasonable for a 4 cyl n/a. it's possible as a crank hp figure. i'd say 2.4L is probably the biggest possible. someone on this board has done it, i forget his member name. its done with a combination of a stroker crank and bigger bore. the biggest possible bore on an h22 with aftermarket sleeves is 90mm w/o having head gasket sealing problems. so use the equation to get displacement using 90 mm as the bore and find out the stroke u need. you can go higher than 11:1 comp ratio too. you'll have to if u want that much hp.
Old Feb 25, 2003 | 03:26 PM
93accordEX's Avatar
talk to 2point6. he originally went through two different 2.6 stroker kits, and then did his own 2.4 for more reliability. he puts out 229whp (before euro-r manifold and something else I forgot now) with 12:1 compression and pretty much all the mods that you seem to have listed. so good luck with your 300hp.
Old Feb 25, 2003 | 05:47 PM
sslude's Avatar
Default Re: 2.??? Prelude (93accordEX)
your'e gonnn have to do a lot of mods to get 300 hp out of a honda. get higher compression, and tune everything i am prettyusre youll be able to get about 25-280hp, maybe not eve, but 300 is really high for a honda
Old Feb 25, 2003 | 05:49 PM
PrecisionH23a's Avatar
then buy a turbo
Old Feb 25, 2003 | 10:27 PM
da94ludesi's Avatar
r&d gets 2.6 but they recommend 2.4 They get app 260 hp to the wheels.....and if you want that much horsepower NA its gonna be a pain, i agree with gude, get a turbo
Old Feb 26, 2003 | 01:44 AM
myh22's Avatar
Default Re: 2.??? Prelude (da94ludesi)
its not that i dont like having a turbo fella's. i just think that going n/a would more challenging. im all up for a challenge, which is why i wanna go n/a. maybe a little later on down the line i'll get a turbo, but for now, whatever needs to be done to at least get close to 300 is what im gonna do. more power to the owners of a turbo charged lude.
Old Feb 26, 2003 | 03:01 AM
96SR-V's Avatar
here's some advice...I went the N/A route already...did everything your looking to do ecu swap, cams, S pistons, port n polished head, all the bolt ons etc etc...netted me just over 200 whp... Although the car is capable of high 13's it still cannot compete w most well built turbos. If your really serious about going fast get a turbocharger. If not go N/A but realize your gonna spend close to the same and your results won't even be close to the same...
Old Feb 26, 2003 | 06:25 AM
satan_srv's Avatar
Default Re: 2.??? Prelude (96SR-V)
I tend to agree with Marc here, I mean I did everything too and got 203whp. Now I am doing some crazy destroking madness to get the high HP I am looking for.
Old Feb 26, 2003 | 12:45 PM
optikal_blitz's Avatar
Default Re: 2.??? Prelude (satan_srv)
not sure if you've checked this out- but it's gota be one of the most concentraded sources of n/a info and discussion ive read on this board: https://honda-tech.com/zerothread?id=180883
good luck w/ your n/a beast...it's gonna be an expensive journey.
--Ray
Old Feb 26, 2003 | 01:20 PM
dvsracergirl's Avatar
our shop has done it to 2.5......its possible....jut make sure you build the engine right.
Old Mar 9, 2003 | 08:49 PM
Quiklude's Avatar
Default Re: 2.??? Prelude (b18onboost)
yeah, while your at it can you make my h23 into a V8
Old Mar 10, 2003 | 06:44 AM
rjr162's Avatar
Default Re: 2.??? Prelude (Quiklude)
how 'bout welding two NSX motors together for me and I'll stick the V12 into a 80 civic
Old Mar 10, 2003 | 07:07 AM
roadawg's Avatar
300 WHP out of 2.2 liters without a turbo isnt going to happen. Think of it like this, 300 WHP is about roughly 350 or 375 crank HP which is about 175 HP per liter NA very diificult to achieve. My advice if you want that much HP get a Turbo..
jethro707
Nov 19, 2010 08:33 PM
JDMorgan
Sep 9, 2004 11:28 AM
Black R
Jul 2, 2004 08:25 PM
AK94GSR
Mar 11, 2003 12:07 PM
