vortex 520 kit
Old Sep 13, 2008 | 06:42 AM
SIVIC 3's Avatar
Default vortex 520 kit
as some of you may know. my 05 cbr 600rr came with rear arm extenders on it from the dealer. the back is stretched out over 6". i wanted to put the wheel back where it should be, so i purchased the vortex 520 kit -1/+2 in a 15/45. it also comes with a RK520xso gold chain. so i am on the way to bringing it back. i was wondering if anyone has any experience with the brand or this exact setup??
Old Sep 13, 2008 | 07:47 AM
fatboy01's Avatar
Default Re: vortex 520 kit (SIVIC 3)
It's a good kit. If you went with an aluminum rear sprocket it won't last as long as a steel one, but other than that I think you will be happy with the results.
Old Sep 13, 2008 | 03:37 PM
SIVIC 3's Avatar
how long are we talkin?
Old Sep 14, 2008 | 10:55 AM
pinkspider's Avatar
I installed it on my 600rr. I have no complaints so far. I went -1 in the front, stock in the back. rpms are higher, mph is off. thats all.
Old Sep 14, 2008 | 11:06 AM
fatboy01's Avatar
Default Re: (SIVIC 3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SIVIC 3 &raquo;</TD></TR><TR><TD CLASS="quote">how long are we talkin?</TD></TR></TABLE>
5-7k miles for aluminum.
Old Sep 14, 2008 | 12:14 PM
EngineNoO9's Avatar
Default Re: (fatboy01)
If you're gonna go 520 don't be a ****** and get **** sprockets. Get the following for 520:
AFM front sprocket
Stealth Rear Sprocket
DID 520 chain
SIVIC 3's Avatar
is the mph going to be off on a -1/+2 setup?
Old Sep 14, 2008 | 12:26 PM
EngineNoO9's Avatar
yes. By a lot. Get a speedohealer
Old Sep 14, 2008 | 12:28 PM
TypeR864's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SIVIC 3 &raquo;</TD></TR><TR><TD CLASS="quote">is the mph going to be off on a -1/+2 setup?</TD></TR></TABLE>
Yes, I have a -1/+2 setup on an 01 f4i and at a true 40mph your speedo will read about 45mph and at 70mph it reads about 80mph. I have the vortex sprockets with DID chain and I have zero complaints thus far. However, the next time I do new sprockets and chain I am going to keep the front sprocket stock and go with a +4 rear. It will give you the exact same results as a -1/+2 setup without the extra wear of the smaller front sprocket. There is a huge writeup on it over on sportbikes.net and because of the smaller front sprocket the chain has to make a tighter turn around the shaft making the chain wear faster. Just my .02
CRAZY-EG9
Apr 14, 2008 07:12 AM
AFTERZERO
Suspension & Brakes
Mar 16, 2005 09:12 AM
bubbajim
Feb 8, 2004 10:49 AM
Kidnkorner
28
Jan 12, 2004 03:39 PM
Hbgsr
Jul 21, 2003 07:26 PM
