open headers
Old Oct 8, 2004 | 12:25 AM
situner87's Avatar
Default open headers
what will result from running a fuel injected bike open header with no power comander or anythin? i kno that with a carb bike u would need to re jet it to richen the mixture. but would a stock ecu be able to correct the mixture enough to save the motor? any help would be great...
Chris
Old Oct 8, 2004 | 12:43 AM
Son's Avatar
Son
Default Re: open headers (situner87)
hearing loss...
There is a way to richen or lean out without the use of a pc on an 03-04 R6. Not sure for an F4i though. I'll check later... need sleep.
Modified by Son at 1:55 AM 10/8/2004
Old Oct 8, 2004 | 12:54 AM
situner87's Avatar
Default Re: open headers (Son)
actually its not that bad. everyone around me cant here **** when i go full throttle... im just curious if it will lean out too much and tear the motor apart. im gunna rebuild the motor if i go turbo, but im just wonderin otherwise.
thanks
Chris
Old Oct 8, 2004 | 02:06 AM
Mike Panic's Avatar
you run a really good chance of melting pistons - there is no performance gain to running headers only on a modern sportbike
Old Oct 8, 2004 | 09:31 AM
Son's Avatar
Son
Default Re: open headers (Mike Panic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mike Panic &raquo;</TD></TR><TR><TD CLASS="quote">you run a really good chance of melting pistons - there is no performance gain to running headers only on a modern sportbike</TD></TR></TABLE>Melting pistons? Maybe cracked pistons? I was thinking he might drop a valve.
Old Oct 8, 2004 | 02:29 PM
Etylorcen's Avatar
I doubt he'll melt a piston, but he most likely will mess up his valves. Also going deaf and being extremely dirty when he gets off his bike. Open header on a sportbike.....thats got to be one of the most idiotic things i've heard in a while.
Wait nm....this is the f4i turbo guy hahaha. 2nd most idiotic thing.
1slammed92
Motorcycles
Jul 12, 2009 12:54 PM
1slammed92
Mid-Atlantic (Sales)
Jul 9, 2009 05:52 PM
SORMatt
Honda Motorcycles
10
Apr 24, 2007 06:56 PM
SiR HatchAlot
Honda Motorcycles
15
Jun 12, 2004 07:58 AM
hondaZvic
Honda Motorcycles
14
Oct 22, 2003 10:29 AM
