Need help with chain conversion
Old Jul 26, 2004 | 01:54 AM
The_Head's Avatar
Default Need help with chain conversion
OK, heres the deal. I plan on converting my YZF1000R from 532 chain to 530 chain. I'm using the denniskirk catalog as my reference for parts.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by denniskirk &raquo;</TD></TR><TR><TD CLASS="quote"> For 530 conversion use FZR750R '87-'88 Sprockets </TD></TR></TABLE>
My question is which chain length do I buy?
The stock YZF1000 uses 17/46 sprockets and a 532 X 110 chain.
I want to go with the FZR sprockets (47 tooth instead of 42 however) with a 530 chain.
The catalog does list a complete conversion kit for the YZF (80-829) I bought it last year, but it's not right. The rear sprocket is wrong. So this is why I'm buying the stuff seperately.
Old Jul 26, 2004 | 03:16 PM
mos's Avatar
mos
Default Re: Need help with chain conversion (The_Head)
530 and 532 chain are the same length pin to pin. The side plates on the 532 are just thicker. If you're going up from a 46 to a 47 then the chain might need an extra pair of links compared with stock. Depending on how much adjustment you've got, stock length might work fine though. I switched my gsxr from 532 to 520, and I didnt use any items listed for a gsxr at all. I forget what I ended up using.
adamRC51
Honda Motorcycles
14
May 16, 2006 04:59 PM
-slow ej-
Feb 13, 2004 03:25 PM
ahead
Dec 6, 2003 11:50 AM
brian2903
Nov 25, 2003 12:39 PM
