idle problem
Old May 28, 2002 | 08:17 PM
Thasty's Avatar
Default idle problem
Just bought an 85 VF500 as a beginner bike. The bike keeps shutting off after idling too long. Any ideas on the problem?
Nate
Old May 28, 2002 | 08:52 PM
Raz1983's Avatar
Default Re: idle problem (OnlyNod)
Could be carburator setting
could be rusted gasoline tank
could be bad spark plugs as well (which i doubt)
Old May 29, 2002 | 07:20 AM
falcongsr's Avatar
What is this crap?
i am not sure if i understand you correctly, but bikes aren't meant to sit and idle. i think that bike is water cooled - is there a temp gauge? is it overheating? it might be overheating and not show it - its a 17 year old piece of machinery.
Old May 29, 2002 | 08:58 AM
meept's Avatar
I've got one, and let me tell you, they run hot. Ride it and you'll be fine, but sit in traffic and the thing will overheat quickly. You may be getting it hot enough to vapor-lock the carbs, since they're between the V (V4 motor) and soak up LOTS of motor heat...
Old May 29, 2002 | 12:45 PM
Thasty's Avatar
Default Re: idle problem (meept)
It dosen't over heat. If I turn it on and ride it up the street and put it in neutral the bike will turn off. Its relitavley easy to turn back on, and it will happen again until its fully warmed up. Then it will only happen maybe once.
Old May 29, 2002 | 01:04 PM
Raz1983's Avatar
Worn out pistons?
I remember when i messed up my pistons, when the motorcycle was cold it wouldnt idle at all. but when it warms up, it would be relatively ok.
Old May 29, 2002 | 03:31 PM
Thasty's Avatar
Default Re: idle problem (Raz1983)
Worn out pistons?
How did you mess em up?
Old May 29, 2002 | 04:06 PM
meept's Avatar
What's your idle speed set to?
Old May 29, 2002 | 05:56 PM
Thasty's Avatar
Didn't even think it had an adjustment screw. Does anyone know where the screw may be located? I dont think that would be the case though. only because it does idle normally on occasion.
Old May 29, 2002 | 07:11 PM
meept's Avatar
Idle adjustment screw is between the front 2 carbs, facing forward. You can reach it best from the right side of the bike...though it's annoying to adjust when the motor is hot. Normal idle once the bike is warm is 1500 rpm.
Old May 29, 2002 | 08:44 PM
falcongsr's Avatar
What is this crap?
do those carbs leak at all? they could be gummed up or letting in air or something.
i hear those carbs have issues at this age - and they are a real pain to work on cause they are down in the V so i bet they've never been pulled and properly reworked.
Old May 30, 2002 | 11:03 AM
Raz1983's Avatar
Worn out pistons?
It was a two-stroke motorcycle, and i ran out of 2-stroke oil. ive done that twice
dumb me
Old May 30, 2002 | 04:27 PM
Thasty's Avatar
Thanks Meept. That was definatly the problem. Seems like the screw was loose to the touch. Doesn't 1500 RPM seem to high though?
[Modified by OnlyNod, 1:19 AM 5/31/2002]
Anivrom
Honda Motorcycles
Mar 31, 2016 03:33 PM
av_shadow700
Honda Motorcycles
Jun 7, 2011 08:25 PM
tmkpres
Honda Motorcycles
Apr 4, 2005 10:18 AM
NitrousFed900
Honda Motorcycles
15
Jan 29, 2005 05:36 PM
Newkdog
Honda Motorcycles
10
Jul 5, 2004 05:54 PM
