I have a Problem!?!
Old Jun 12, 2007 | 09:56 PM
lowRIDAH's Avatar
Default I have a Problem!?!
I turn the key, engine start switch on...ignition. The bike turned on then turned off right away. I tried again and the same thing happened. when i would hold the ignition switch the bike stays on until i let go.
the headlights and blinkers don't work either. Also when I flipped the engine start, the FI light didn't come on and that noise that you usally hear(i guess the fuel injection) was nowhere to be found.
when I was heading to the gym, the bike was fine. When I came out 1.5 hours later this happened?!
Anyone know what the problem could be??
is it common?
I have a 2001 F4i btw.
thanks for any help/advice in advance...i'm so frustrated!
Old Jun 12, 2007 | 10:03 PM
marmaladedad's Avatar
Has the bike sat for awhile? How old is the battery?
Old Jun 12, 2007 | 10:07 PM
lowRIDAH's Avatar
it hasn't been sitting at all. i've been riding it everyday for the past week with no problems.
not sure how old the battery is, just bought the bike 2 weeks ago
Old Jun 12, 2007 | 10:30 PM
What kind of trips have you been taking? If the previous owner has not replaced the battery yet, then it's possible the battery s dying (most only last a few years). Some auto-parts stores will check your battery's condition for you for free. You can also use a multi-meter to check your bike's charging system.
Old Jun 12, 2007 | 10:36 PM
lowRIDAH's Avatar
trips have been anywhere from 5 minutes to 45 minutes
if the battery was dying wouldn't the bike stay on after i start it? cause I jumpstarted it and it was the same.
Old Jun 12, 2007 | 10:37 PM
If the charging system isn't doing it's job, the bike will die soon after jumping it.
Old Jun 12, 2007 | 10:50 PM
lowRIDAH's Avatar
Default Re: (marmaladeboy)
k cool, i'm gonna check the battery in the morning.
thanks for the help
Old Jun 12, 2007 | 10:52 PM
Good luck man.
I forgot to add, you may want to check the fuses. Unlikely, but might as well look.
Old Jun 26, 2007 | 01:00 PM
lowRIDAH's Avatar
just wanted to update in case anyone has the same problem.
took it to the shop last week and they said it's the engine on/off switch that was the problem. part should be in on Friday and they'll see if anything else was affected
nveley22
Honda Motorcycles
Sep 15, 2013 05:47 PM
the_gambler
Honda Motorcycles
May 15, 2009 06:05 AM
b18C1_liLkyLe
Honda Motorcycles
Oct 9, 2006 09:19 AM
UNforgivABLE
Honda Motorcycles
Mar 12, 2006 09:08 AM
crxgurlllll
Honda Motorcycles
10
Aug 26, 2005 10:23 AM
