ATV Problems
Old Jun 16, 2004 | 02:41 AM
Evil_Pull's Avatar
Default ATV Problems
I got a 300 Honda ATV 01 model. It fires up and runs for about 5 minutes then the exhaust gets red hot and the thing shuts off. After that I cant get it to fire again. I thought something might be clogging it , But I checked and nothing. It got so hot once it melted the cooling plate down.
Old Jun 16, 2004 | 06:51 AM
stockcrix1616's Avatar
Default Re: ATV Problems (Evil_Pull)
300 what? rancher? 300ex? might need to give some more information. did you change anything before it started acting up? it sounds like its running lean.
Old Jun 16, 2004 | 08:42 AM
Z's Avatar
Z
Old User.
Default Re: ATV Problems (stockcrix1616)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stockcrix1616 &raquo;</TD></TR><TR><TD CLASS="quote">300 what? rancher? 300ex? might need to give some more information. did you change anything before it started acting up? it sounds like its running lean. </TD></TR></TABLE>
That was my first thought too. If it's running lean it will get real damn hot. If you run it like that too long the it will sieze the piston. Do not run it like that.
Old Jun 16, 2004 | 09:41 AM
Default Re: ATV Problems (Z)
yep, if its melting things im sure you have already done some damage and will be seeing a loss in compression. ive seen actual race teams jet the bike by useing the pipe color to tell if its lean or rich, but thats mainly on 2 strokes. since yours is running lean, maybe you have something stuck in the main jet and starving it for fuel. its got to be something around or in the carb unlesss you changes anything like removing the air box lid or anything like that.
Z, im sure dealing with a 2 stroke youve seen the pipe turn blue if your useing a bare metal one.
BB4vTak
Sep 2, 2009 11:20 AM
nitroice40
Aug 24, 2008 06:00 AM
zirac50
Mar 23, 2007 10:28 PM
civtegra_hybrid
Oct 3, 2004 07:21 AM
honda9369
Sep 22, 2004 03:45 PM
