Adjustable?
Old Oct 3, 2005 | 08:22 PM
HS2G's Avatar
Default Adjustable?
I have been researching on a Honda CBR600RR. I hope to buy it next spring or summer, but the only thing I am a little worried about is the seat height. I understand that they have adjustable rebound and compression-damping adjustability of 0-4 inches. Does that mean that I can lower the bike 4 inches? Not that I want to lower it 4 inches, maybe about 1-2 inches. I can tip toe my right foot on the ground while my left is on on the gears, but I would feel much more comfortable with both feet on the ground. I won't be riding it like I stole it, just cruising around the streets and taking turns at like around 10-20MPH.
So it it ok to adjust the spring for 2 inches lower?
Old Oct 3, 2005 | 08:24 PM
MSchu's Avatar
My Name is Nobody
Default Re: Adjustable? (HS2G)
Woe there lil buckeroo, set your suspension for riding conditions... Suspension does little for you while sitting still
EGlovr's Avatar
i would look into shaving the seat before you go messing with how the bike handles.
.02
Old Oct 3, 2005 | 08:25 PM
EkEli's Avatar
rebmem roines
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HS2G &raquo;</TD></TR><TR><TD CLASS="quote"> I won't be riding it like I stole it, just cruising around the streets and taking turns at like around 10-20MPH. </TD></TR></TABLE>
wft?
Old Oct 3, 2005 | 08:29 PM
big pete's Avatar
Default Re: Adjustable? (EkEli)
get a harley?
Old Oct 3, 2005 | 08:33 PM
MSchu's Avatar
My Name is Nobody
Default Re: Adjustable? (big pete)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by big pete &raquo;</TD></TR><TR><TD CLASS="quote">get a harley?</TD></TR></TABLE>
Old Oct 3, 2005 | 09:02 PM
marmaladedad's Avatar
Practice practice practice.
How short are you?
Even short riders can manage without both feet on the ground.
Old Oct 3, 2005 | 09:38 PM
yimmy's Avatar
Default Re: (marmaladeboy)
Jason Disalvo is 5'2 and manages to take corners at 10-20mph +...It just takes some getting used to
Old Oct 3, 2005 | 09:55 PM
bustdesenuts's Avatar
Default Re: (EGlovr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EGlovr &raquo;</TD></TR><TR><TD CLASS="quote">i would look into shaving the seat before you go messing with how the bike handles.
.02</TD></TR></TABLE>
shave the seat down and get a thin layer gel pad or something. it should help a little
Old Oct 3, 2005 | 09:59 PM
DOHCter's Avatar
you can adjust the compression and rebound dampening.. emphasis on dampening.. not 0-4 inches of dampening.. you can't lower a bike without buying parts, like lowering links.. if you try to adjust it with the spring perch like you might your car, you change the preload of the spring, and the result would be an unfriendly bike to ride because you would have a softer preload fi you tried to lower it with the spring perch.. just tip toe.. long as your feet both touch the pegs when your riding, who cares if you can only tip toe when stopped.. i can't flat foot both feet and i'm 5'8'
Old Oct 3, 2005 | 10:04 PM
MSchu's Avatar
My Name is Nobody
Default Re: (DOHCter)
why would you need to put both feet down anyway? I always laugh to myself when I see nearly every rider in so cal smoking the hush puppies from a stop
Best to use the pontoon method until you get some balance? better to stay off the public roads.
Old Oct 4, 2005 | 03:57 PM
integrator43's Avatar
Default Re: (MSchu)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MSchu &raquo;</TD></TR><TR><TD CLASS="quote">why would you need to put both feet down anyway? I always laugh to myself when I see nearly every rider in so cal smoking the hush puppies from a stop
Best to use the pontoon method until you get some balance? better to stay off the public roads.</TD></TR></TABLE>
i love watching cruisers drag feet all the way across an intersection and then some. i weep when i see sportbikers do the same.
sometimes i wonder if they think they are gaining style points by doing the pontoon drag? or is that catamaran?
Old Oct 4, 2005 | 04:38 PM
rdblckSV650S's Avatar
Default Re: (integrator43)
i think if it's going to bother you you should search for a bike that's got a lower seat height for yourself. What's the point of straining yourself on an RR if you're just going to cruise around on it? Get a cruiser.
Old Oct 4, 2005 | 06:16 PM
tvrsir's Avatar
Default Re: (slvrblckf4i)
i have an 05 r6 i bought not too long ago, i'm 5'2" 110 lbs. i shaved the seat down 2 inches, and put on foot down when stopping and switch foot depending on road crowns. i have been riding for about 2.5 months and learning still.
get some frame sliders. trust me you will drop it. i dropped my brand spanking new bike 4 times in 2 weeks, and after those times i have learned to balance the bike when stopping. it has almost come natural now. that part was the only part i was afraid of. now i am not afraid to ride because i can put my foot down. YOU CAN RIDE WITH ONE FOOT DOWN AT A LIGHT . when riding who puts both foot down anyways TELL YOU NOW THOUGH, the 600rr seat is freaking thin hard as a rock and shaving that would let you sit on the subfrmame
Old Oct 4, 2005 | 06:53 PM
HS2G's Avatar
Default Re: (tvrsir)
I think it was a Suzki GSX-R750 that I sat on. I could put my right foot on the ground while having my other foot on the peg. The RR I believe is little lower than a 750. Guess I just have to go sit on an RR or an F4i.
NoobieRyder
Honda Motorcycles
17
Dec 17, 2009 01:13 PM
Nameless Warrior
Honda Motorcycles
38
Sep 18, 2007 11:02 PM
tvrsir
Honda Motorcycles
10
Apr 5, 2005 05:22 AM
HC313
Honda Motorcycles
Aug 20, 2004 06:23 AM
Dream
Honda Motorcycles
11
Apr 6, 2004 07:24 PM
