Honda Fit Honda Fit (Jazz)
need some help
Old Jan 1, 2009 | 04:43 PM
ramiro p's Avatar
Default need some help
i just change my bad clutch with a new one. I have put evething back together but my clutch pedal when pressed down there is no tenssion and it does not bounces back up. I been bleeding the for like 1 hour I even change the slave cylinder with a new one and is till no pressure on the pedal. there are lots of bubbles coming out but no pressure.what is going on?
Old Jan 1, 2009 | 09:14 PM
NSfit's Avatar
Default Re: need some help
sounds like you need to just keep bleeding it and make sure your always refilling the reservoir.
do you have a friend helping you or are you using one of those bleed it your self kits?
Old Jan 2, 2009 | 06:29 PM
jrzy2nR's Avatar
recheck all your work first. and since there is a lot of bubbles...indication of a lot of air...keep bleeding it
92ehatch
Jun 23, 2006 07:10 PM
LudeCris
May 21, 2006 09:47 AM
Sick'Lude
Jun 14, 2005 05:01 PM
bsixteen
Apr 17, 2005 04:06 PM
kamdog
Nov 14, 2003 10:30 AM
