Honda Fit Honda Fit (Jazz)
Door lock problem
Old 03-23-2016, 05:01 PM
markakis3100's Avatar
Default Door lock problem
The passenger side door in my 2011 Fit does not unlock with the key fob or by using the latch on the interior door handle. I took the door panel off to see what it could be and the cable going from the interior door handle latch to the actuator seems to be the problem. The cable itself has a thinner cable inside of it that gets pushed in and out to unlock/lock the door. The problem is that I cannot push that interior cable all the way in so the door can unlock. I think just replacing the cable would do the trick, since the actuator itself is getting power and tries to unlock the door. The problem is that I can't get the actuator out of the door since I can't get to the screws on the side of the door (since I can't unlock it either way).
Is there a manual latch inside the door I can get to or is there anything else I can do to get the door actuator out?
Thanks in advance for any suggestions.
Old 09-01-2016, 08:12 AM
DooDooBrownEg's Avatar
Default Re: Door lock problem
Check with your dealer to see if your vehicle is effected by the door actuator recall.
Libradh@aol.com
01-24-2019 09:16 AM
jus455
03-07-2015 08:21 PM
JohnnyWash1
09-29-2009 09:26 AM
idriveadelsol7
03-20-2005 06:06 AM
Quick Reply: Door lock problem
