Honda CR-V & Element 2WD & 4WD Element & CR-V
Shopping for my next Honda: 2005-06 CR-V
Old 09-19-2015, 04:53 PM
Civic_chick's Avatar
Default Shopping for my next Honda: 2005-06 CR-V
After owning but regrettably selling my 2005 Civic, I'm looking for another Honda to serve as my daily driver. I've always really loved the 2002-2006 CR-V and have begun my research about them. Can somebody attest to the these weak points I've put together to serve as my check list when shopping for a 2005 or 2006 facelift model. what am I missing?
1-Valve adjustment check
2-Water pump, check the weep hole and if there is coolant present, could be a sign it's bad
3-A/C system - check for a cracked condenser tank. Check expansion valve first before changing compressor. Right before the compressor fails, signs are: odd noises & blowing warm air. Do NOT use A/C from that point. If the A/C compressor fails, it'll shoot metal shards throughout the system and force you to replace every hose and part.
4-Rear differential fluid flushed and replaced
5-
Lastly, has anybody noticed how well these things hold their value?? In Canada, there are a number of 2005/06 selling for 9K+ CAD. O_o
Thanks guys!
Old 09-22-2015, 02:09 AM
wingmantx's Avatar
Default Re: Shopping for my next Honda: 2005-06 CR-V
I believe the expansion valve is behind the dash. Not sure How you can "inspect" it without removing the entire dashboard
Old 09-22-2015, 11:45 AM
BigBerz's Avatar
The valve adjustment isn't as important as in the previous models.
Berz out.
Old 09-24-2015, 07:29 AM
Thanks for the replies, guys.
Old 09-27-2015, 02:03 PM
Honda4Life.'s Avatar
Loved my 06 for just over a yr and a half. Put just under 20,000 miles on it before 2 idiot made me total it. Its been deemed their fault. Might get another but not sure.
When I bought it.
Just over a month ago now.
And when I left it just over a week ago now.
Old 09-29-2015, 08:29 AM
BigBerz's Avatar
Holy **** man. Glad your ok. Do you think your Bull Bar helped in the collision?
Berz out.
moneymike916
Honda Civic (2006 - 2015)
06-24-2018 08:31 PM
EM2Civic
07-16-2010 02:51 PM
vansxskater
Honda Civic (2001 - 2005)
04-02-2010 07:12 AM
C R X
12-07-2003 11:58 AM
Quick Reply: Shopping for my next Honda: 2005-06 CR-V
