Green key light on CRV flashing
Green key light flashes, car cranks but won't start. ( doesn't do it all the time ) engine managment light stays off. When the engine managment light eventually comes on key light goes off and car starts. Honda 2005 CRV 2.2 Diesel UK model.
Neil.
Re: Green key light on CRV flashing
You have problem with the immobilizer system
When the car doesn't start, it is because the chip in the key isn't recognized by the ECU
It can be caused by a number of reasons
Hi ClabbeB and thank you.
Do you know if there a list of things to check and maybe find the fault through process of elimination
Neil.
Neil.
Unfortunately not.
Easiest is to habnd it to a dealer so they can check what exact is the problem as it can be a number of different reasons.
If you do a quick google search you will get a number of results, so the problem is not unheard of.
gibnihtmus
07-18-2010 09:14 PM
jdmfreak1992
Honda Civic (2001 - 2005)
10-25-2008 05:10 PM
