Honda CR-V & Element 2WD & 4WD Element & CR-V
Green key light on CRV flashing
Old 03-08-2018, 02:09 PM
Z1300blue's Avatar
Default Green key light on CRV flashing
Green key light flashes, car cranks but won't start. ( doesn't do it all the time ) engine managment light stays off. When the engine managment light eventually comes on key light goes off and car starts. Honda 2005 CRV 2.2 Diesel UK model.
Neil.
Old 03-09-2018, 01:59 AM
Z1300blue's Avatar
Default Re: Green key light on CRV flashing
Plz Can anyone give advice.
cheers.
Neil.
Old 03-11-2018, 09:02 PM
ClabbeB's Avatar
You have problem with the immobilizer system
When the car doesn't start, it is because the chip in the key isn't recognized by the ECU
It can be caused by a number of reasons
Old 03-12-2018, 12:02 PM
Z1300blue's Avatar
Hi ClabbeB and thank you.
Do you know if there a list of things to check and maybe find the fault through process of elimination
Neil.
Old 03-14-2018, 01:01 AM
ClabbeB's Avatar
Unfortunately not.
Easiest is to habnd it to a dealer so they can check what exact is the problem as it can be a number of different reasons.
If you do a quick google search you will get a number of results, so the problem is not unheard of.
civc12
Honda Civic (2001 - 2005)
08-09-2020 02:06 PM
gibnihtmus
07-18-2010 09:14 PM
jdmfreak1992
10-25-2008 05:10 PM
YaMaJeSty
Honda Motorcycles
02-09-2008 12:47 PM
frostt3ch
04-04-2004 06:06 PM
Quick Reply: Green key light on CRV flashing
