Honda CR-V & Element 2WD & 4WD Element & CR-V
Can I re-use the pressure sensor from a damaged rim on a new rim?
Old 03-21-2015, 10:57 AM
CRVINMICH's Avatar
Default Can I re-use the pressure sensor from a damaged rim on a new rim?
I went over a pretty good pothole in my 2007 CRV and damaged my rim. (Welcome to Michigan!). The car is drivable but vibrates a bit at highway speeds and I'm inclined to replace it with an aftermarket rim. Can I simply remove the TPMS sensor from the damaged OEM rim and put it in the new rim?
Old 03-21-2015, 11:29 AM
Global Moderator
tech8's Avatar
Default Re: Can I re-use the pressure sensor from a damaged rim on a new rim?
Definitely, you can reuse the TPMS sensor if it wasn't damaged.
Although not always done, it is recommended to use a new valve grommet and washer though.
Old 03-21-2015, 01:00 PM
CRVINMICH's Avatar
Thanks!
malottauto
11-28-2017 10:38 AM
Dc2phil
09-17-2012 01:34 PM
sony224422
06-17-2011 05:08 PM
prostreetonline
07-10-2004 12:21 PM
Quick Reply: Can I re-use the pressure sensor from a damaged rim on a new rim?
