Honda CR-V & Element 2WD & 4WD Element & CR-V
Buying 2001 CR-V B20Z1 any weaknesses?
Old 08-18-2012, 10:08 AM
BeastlyB's Avatar
Icon2 Buying 2001 CR-V B20Z1 any weaknesses?
I am thinking about buying a CR-V.
2001
B20Z1
93k miles (belt done at 77K)
I like to know if there are weaknesses i need to look out for.
His son used it for the last few months and may not have been to kindly with it
Old 08-18-2012, 10:30 AM
zelseman's Avatar
Default Re: Buying 2001 CR-V B20Z1 any weaknesses?
Look for problems just like you would any other car. Make sure the engine does not tick or knock and runs smoothly. Check for suspension travel on your test drive. Make sure everything works inside (cruise, a/c, heat, radio, ...). Check tire tread on all tires and check the oil and see what color it is and if the motor looks healthy.
Don't let that always be a red flag. For example, I am a gearhead and my father is not. When I drive his car I baby it. He however, gasses it at every light and rides his breaks 24/7. So I wouldn't assume that a son driving his dad's car is bad.
Good luck on the car search!
Old 08-18-2012, 10:54 AM
BeastlyB's Avatar
Thanks for the reply,
And you are right about the son thing,
it is a 2001 so last year of production of that model so i assume all the flaws are taken out.
Just trying to find out if there are problems with these models in any way.
Old 08-18-2012, 11:31 AM
black0hatch's Avatar
b20's are natorious for the exhaust valves make sure there adjusted properly.
95-EX
01-23-2018 12:33 PM
dornon13
10-28-2004 05:36 AM
Integgedout
10-24-2004 10:12 AM
94HybridEX
02-20-2003 11:57 PM
PyR01-0347
04-03-2002 04:54 AM
Quick Reply: Buying 2001 CR-V B20Z1 any weaknesses?
