98 CR-V 4wd Rear Bearing Bad
Looking for some insight into repairing my CR-V. The right rear bearing is bad but im not sure if I should try just a bearing replacement or just do a whole hub assembly replacement. If I went the hub replacement route this would eliminate having to press the bearing in and out correct? Im also airing on the side of caution by replacing the whole hub in case the on in there is damaged from the bearing being bad right? Any insight or info would be appreciated.
I dont have tons of specialty tools but can rent some from auto zone if needed. Just wondering which way would be the easier route for a DIYer.
Re: 98 CR-V 4wd Rear Bearing Bad
if i remember right the 2wd have the bolt in the 4wds have a press in if you have acess to a press its fairley easy just if you have abs make sure the magnetic side on the bearing goes down. should be the brown side
PaChiLa Leader
02-18-2009 05:21 PM
jasonb
06-22-2002 07:17 AM
