what would cause turn signals to stop signalling?
Old 02-07-2010, 10:21 PM
BrayzieEF9's Avatar
Default what would cause turn signals to stop signalling?
like the title says
Old 02-07-2010, 10:31 PM
ryanevansoh's Avatar
Default Re: what would cause turn signals to stop signalling?
shorting out, relay fried. did you check anything?
Old 02-07-2010, 10:33 PM
BrayzieEF9's Avatar
fuses are fine bulbs are fine everything lights up it just doesn't signal
DCRB's Avatar
a short, bad flasher, something's unplugged, all the bulbs are burned out, lots of things i guess. what exactly are you experiencing? are they just plain not working or are they staying on solid or are fuses blowing? we need more info
Old 02-07-2010, 10:35 PM
well my guess is that there is a short so check your wires
Old 02-07-2010, 10:37 PM
del_soldier93's Avatar
check ur hazard switch....
Old 02-07-2010, 10:38 PM
BrayzieEF9's Avatar
i mean when not signalling i mean theres no signal light if there was a short the signal light would just blink fast im experiencing no signals at all everything lights up and DCRB i think i got my sidemarkers from you lol
Old 02-07-2010, 11:02 PM
TheAsian's Avatar
Check your switch. Measure voltage and resistance accross the switch. If all turn signals are not working that is where i would start after fuses.
Grounds would be a good idea to but highly unlikely all failed at once.
Old 02-07-2010, 11:14 PM
BrayzieEF9's Avatar
switch??
Old 02-07-2010, 11:50 PM
TheAsian's Avatar
Check your actual turn signal switch. Ill post up some wiring diagrams for you tommarrow and tell you where to look.
Old 02-07-2010, 11:52 PM
BrayzieEF9's Avatar
alright thx
Old 02-08-2010, 03:36 AM
ef-hatchcrap's Avatar
Its your flasher relay
Old 02-08-2010, 04:48 AM
BrayzieEF9's Avatar
yeah i'll check that too
Old 02-08-2010, 05:29 AM
roadsqueegy95's Avatar
mine use to blow the fuse, but i found a short and that fixed that! id deff look at your flasher relay!
Old 02-08-2010, 06:07 AM
Jenkinsal2's Avatar
Its also possible to have the ICU give you problems like these if it goes bad. It is a white box on the rear of your under dash fuse panel.
Old 02-08-2010, 06:15 AM
terror_storm's Avatar
If the hazard switch is unplugged, the turn signals will not work.
Old 02-08-2010, 07:19 AM
grog's Avatar
I noticed that you said you have added some side markers, if you did add those and wired it wrong it could cause the other blinkers not to work. to check that unplug the wiring to the side markers, then see if your blinkers work.
Old 02-08-2010, 07:39 AM
dr_latino999's Avatar
I'm going to hand Jenkins here a and second that motion, those little things are the bane of my existence on this planet.
Old 02-08-2010, 11:36 AM
TheAsian's Avatar
In the first diagram check you fuses measure resistance accross the fuse or just replace just to make sure.
Next pull your hazz switch out. Check for battery volatage at pin 7 on c715. It is the WHITE/GREEN wire. Use a sewing needle to back probe the connector but dont force it in their. You should have battery voltage.
Next on c715 back probe pin 6 YELLOW wire with the car in access II everything on. You should have battery voltage their also.
Now with the car still in acc II press the hazz switch so it is on and check pin 8 GREEN/WHITE wire you should have battery voltage their. If not Use the Hazz switch test in the picture bellow this.
Im going to skip the relay for now
Look at picture 2. Turn you key to acc II You will need to pull you steering colom apart to get to the connector at the turn signal switch. On the GREEN/RED wire going into the connector c416 make sure you have battery voltage their. Now turn the switch to indicate a left turn and check the GREEN/BLUE wire for battery voltage.
Do the same for the GREEN/YELLOW wire to check the right side indicator.
With the hazard switch off you should have continuity or .1-.2ohms between terminal F-H.
Now with the hazard switch on you should have continuity between terminals A-B-D, and G-H
Let me know what you find where and ill be able to give you more help
Old 02-08-2010, 12:08 PM
BrayzieEF9's Avatar
thx for the diagram TheAsian
Old 02-08-2010, 06:08 PM
BrayzieEF9's Avatar
ye found out the problem it was my flasher relay fuse thx everybody for there input
egboy94
02-26-2011 05:52 AM
BrayzieEF9
02-07-2010 11:17 AM
B204door
Audio / Security / Video
12-21-2006 04:03 PM
6doorsentra
04-09-2006 07:41 PM
Champ White EJ8
12
03-01-2005 09:43 PM
Quick Reply: what would cause turn signals to stop signalling?
