Clutch Cable Question
Hey everyone..first of all my clutch seems to be acting fishy lately..the pedal will get really floppy and have alot of play, it seems as if have no tension for my clutch pedal for about an inch or so then it will hit the normal feeling of pressure and disengage. But when I either give it a good rip or go on a long cruise on the highway the pedal stiffens back up and goes back to normal feeling without the sloppyness and play(for a couple of mins only then goes back) . Now this is on my b16 cable tranny which the cable im guessing seems to be binding up (or so I think), and am going to get a new one. I thought all DA clutch cables were the same but after looking at them online the gsr and ls cable have different part numbers and are slightly different in length. I'd like to know the corect one to get this time, and if you have any other ideas why it is causing this strange activity please help!!..thanks in advanced..
Re: Clutch Cable Question
If you replace the clutch cable and it still does the same thing, then check the clutch pedal pivot point on your pedal assembly for cracking. This is a pretty common issue with these year cars. A pressure plate that is begining to fail will also have similar symptoms.
its got a competition clutch stage 2 clutch and pressure plate that is fairly new, the pivot point area already snapped around thanksgiving time and i took that out and re-enforced it wayyyy stronger than it will ever need to be and was an awesome improvement. i also replaced the collar and bushings where the clutch pivots.
The throw out bearing could be getting stuck on the input shaft part way through the travel of the pedal. I hope that makes sense.
I had it happen to me, the old throw out bearing was getting stuck on the very end of the shaft and holding the pressure plate off of the clutch disk.
Throw out bearing binding on the shaft due to poor/inadequate lubrication.
I realize your clutch/pressure plate are fairly new, but I know several people on here have had issues w/CC pressure plates. If the clutch cable and the external brackets and pivots are in order then you will have to drop the trans and see whats going on in there.
If all this if correct then the problem is most likely with the pressure plate.
When the spring "fingers" on the pressure plate start to lose tension, it will cause the symptoms you are describing. Also a clutch disc that has a loose/broken spring can cause an intermittent problem like this. At this point I think you are going to have to drop the transmission and take a look inside.
In case any of you were wondering the cause or find this in the search section when trying to solve the same problem...It was the clutch cable, the old one was binding up. I bought a new 93 integra ls one and it is better than ever, and the pedal goes down smooth like butter.
In case any of you were wondering the cause or find this in the search section when trying to solve the same problem...It was the clutch cable, the old one was binding up. I bought a new 93 integra one and it is better than every and the pedal goes down smooth like butter.
InJ3cted
05-24-2005 02:16 PM
