wheel hop subject again
Old 05-24-2006, 04:41 PM
I tell doctors what to do
ILcrxsi1's Avatar
Default wheel hop subject again
I"ve got 2 brand new motor mounts, drivers side and front with motor mount inserts. Jimfab traction bar up front and new lower control arms on each side. I still have ******* wheel hop.
Do you guys think new springs and shocks will solve the problem? I've still got the originals on the car, but from what I understand wheel hop is shifting from front to back and not hopping up and down. Suggestions please.
Old 05-25-2006, 04:14 AM
ILcrxsi1's Avatar
Default Re: wheel hop subject again (ILcrxsi1)
bump for morning guys
Old 05-25-2006, 11:47 AM
ILcrxsi1's Avatar
last time
Old 05-25-2006, 01:37 PM
BiG Chris's Avatar
I installed a WR Torque Damper and now ive only got wheel spin
Old 05-25-2006, 01:48 PM
ILcrxsi1's Avatar
Default Re: (BiG Chris)
I didn't know they made one for the crx
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BiG Chris &raquo;</TD></TR><TR><TD CLASS="quote">I installed a WR Torque Damper and now ive only got wheel spin</TD></TR></TABLE>
Old 05-25-2006, 01:49 PM
ludesrv's Avatar
What tires are you running?
Old 05-25-2006, 01:53 PM
ILcrxsi1's Avatar
Default Re: (ludesrv)
yokohama avs es 100's 205 50 15's on rota grids
Old 05-25-2006, 03:13 PM
BiG Chris's Avatar
Default Re: (ILcrxsi1)
I work at Weapon*R and i made one to show people but i didnt get enough positive response to actully produce a large amount but maybe i can make you one.
Old 05-26-2006, 04:15 AM
ILcrxsi1's Avatar
I might be interested. Where does it attach at?
Old 05-26-2006, 05:05 AM
OG Fabricator
weiRtech's Avatar
have you upgraded your rubber bushings in the lca's? it might help a bit.
here is my fcm with rod ends and i also run poly lca bushings. i only get wheel spin now.
Old 05-26-2006, 05:14 AM
ILcrxsi1's Avatar
Default Re: (weiRtech)
I haven't upgraded them, but I did replace the control arms. So the bushings are new they're just not poly or anything.
Old 05-27-2006, 01:36 AM
M15
M15's Avatar
Wheel hop=shitty suspension. I upgraded from omnipower suspension to Tein S-tech springs and I went rrom wheel hop to wheel spin(only a little cause Stock B16's can only spin so much) but I honestly believe that wheel spin is all in your springs. .. get rid of what you have and you will get rid of your problem.
Old 05-27-2006, 01:25 PM
ILcrxsi1's Avatar
Default Re: (M15)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by M15 &raquo;</TD></TR><TR><TD CLASS="quote">Wheel hop=shitty suspension. I upgraded from omnipower suspension to Tein S-tech springs and I went rrom wheel hop to wheel spin(only a little cause Stock B16's can only spin so much) but I honestly believe that wheel spin is all in your springs. .. get rid of what you have and you will get rid of your problem. </TD></TR></TABLE>
so you mean 16 year old stock springs and shocks don't help performance
Old 05-27-2006, 02:11 PM
blah13's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ILcrxsi1 &raquo;</TD></TR><TR><TD CLASS="quote">
so you mean 16 year old stock springs and shocks don't help performance </TD></TR></TABLE>
They should perform at their best now, you followed the proper break in procedure right? Noobs...
Old 05-27-2006, 02:21 PM
ILcrxsi1's Avatar
Default Re: (blah13)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blah13 &raquo;</TD></TR><TR><TD CLASS="quote">
They should perform at their best now, you followed the proper break in procedure right? Noobs... </TD></TR></TABLE> my signup date is directly correlated to my automotive knowledge . people in the tech forums can't read sarcasm
Old 05-29-2006, 12:14 AM
M15
M15's Avatar
So wait a sec. .. you ask a question, people come in here and try to help you then you have the nerve to get sarcastic. .. and you wonder why people flame you? You're an ignorant ***. I hope you and your car wheel hop into a ******* semi!!
Old 05-29-2006, 12:31 AM
*Boostwerks*'s Avatar
Wheel hop diagnosis...
traction bars? yes
good shocks? no... start here.
balanced wheels?
flat spots on the tires?
ect...
You basically answered you own question in the first post. Wheel hop is exactly that. Hoping up and down. Many different things can cause this.
Old 05-29-2006, 05:31 AM
george34's Avatar
Default Re: (Bryson)
I still have wheel hop, and I have stiff motor mounts, tokico shocks, and nuespeed (sp) springs. The only thing that I can think of that would cause this is azenis on wet pavement.
Old 05-29-2006, 05:51 AM
crx_88_si's Avatar
try lowering your tire pressure. too hard will bounce alot easier, softer will allow some movement.
h22sedan01
08-14-2007 02:14 PM
civicsaremean
18
07-23-2007 11:17 AM
playboyace35
02-18-2005 03:01 PM
crx_of_fury
17
01-10-2005 02:33 PM
project-boosteD
05-03-2004 03:00 PM
Quick Reply: wheel hop subject again
