Map Sensor code
Old Jan 10, 2004 | 03:16 PM
Tw1n Turb0 Z's Avatar
Default Map Sensor code
Getting code 3, causing the car to run like crap at odd times, and I was wondering is this the sensor that the plug attaches to on the side of the throttle body?
Old Jan 10, 2004 | 03:45 PM
RCautoworks's Avatar
Default Re: Map Sensor code (Tw1n Turb0 Z)
Code 3 - MAP Sensor
Usually means there is something wrong with the sensor itself.
Has the the most control over the fuel injector pulse width.
When the MAP voltage is too high check code 5.
incorrect cam timming
incorrect iginition timming
restricted exhaust
excessively worn engine or leacking valves
Testing - Voltage varies from about .6v to 2.7v. Running no load will usually be less then 1v or slightly lower, when warm and idling. Under heavy load 2.5 to 2.75 volts. PA sensor should also read close to the same with Engine Off and Key On (EOKO).
Condidtion MAP Volts Inj PW Exhaust CO
Normal .94 2.0 ms .3%
Vacuum Leak Created on MAP Hose 1.13 2.3 ms 6.5%
Bigger Vacuum Leak Created on MAP Hose 1.25 2.7 ms 9.9%
MAP Sensor Wires:
1 White/Red
1 Green/White
1 White
Old Jan 15, 2004 | 09:02 PM
silverbulletgsr's Avatar
Default Re: Map Sensor code (90blackcrx)
So if my map sensor is reading 3.1 volts under boost. Would this be the reason that it is cutting out as soon as it hits 3.1 volts everytime?
Old Jan 15, 2004 | 11:42 PM
Xsi's Avatar
Xsi
Are you still using a stock MAP sensor with boost?
Old Jan 15, 2004 | 11:48 PM
I have another question. I am now getting code 1 as well but something strange is happening. I am getting 1 blink, then a pause, then 1 blink again, then 3 blinks (map) and then 17 blinks(VSS) what are the significance of the (2) one blinks? Anyone
tek9_ej2
Apr 10, 2010 05:13 AM
FSS13foxtrot
Jan 20, 2008 06:23 AM
92ehatch
16
Feb 19, 2007 11:41 PM
Sci_v_icI
Apr 5, 2006 10:44 AM
