ls motor into 91dx need help searcheedddddd
ok listen guys i bought the b-series mounts off ebay and thinking bout getting the harness but...here's the deal my friend crashed his integra the whole bak got smashed in so he giving it to me its a 92 gs integra wit the ls motor in it i kno this is obd1 and my car obd0.the whole front clip is there so wat do i need to take off to do the swap and do i need to buy a harness conversion? cant i just use the nice uncut harness in the integra? and about shifter linkage how long do i have to cut the stock one to fit the crx? and is it worth it? or should i buy the hasport one? need info guys doing swap sat mourning......if anybody did one and kno about problems i'm gonna run into email me nysikcrx@aol.com or reply thanks guys
that 92 teg would bave a b18a1...everything will go right in your crx if I am not mistaken.....
somebody please correct me if I am wrong though, it is 2:30 am and its entirely possible I am missing something
That is an OBD1 motor, so you would need to either convert the car, or convert the motor.
One thing I woudl suggest, look at back issues of Sport Compact Car(try a big library they often have back issues). I forget which issue, but maybe the may or june one this year had a very good and detailed article about swapping a B18A1 into a 1991 Civic DX hatch. It will help you through the process. It had Street Racing Tokyo on the cover.
I believe you have to shorten the linkage 3", as a general rule, but different engine mounts locate the engine in different places, so until you get it all installed, it might be hard to say. Unless you are using the Hasport mounts, I don't know if the hasport linkage will be correct.
You'll need the integra axles, radiator hoses, throttle cable, too.
yes, he will need everything basically out of the teg...including the pr4 ecu. scc does have a good how-to...somewhere back in the back issues. Wish I had more details for you , but a good person to ask some questions to would be Screamincivik on this board...he has been through hell and back doing LS swaps, b18a mostly. I have the B18B, but it was in the car when I bought it...I just pulled it and put it right back in after rebuild so I had all the parts here.
Give him a hollar on PM's he will respond quickly
o ok thanks guys and does can anybody send me the info how to convert my car to obd1? do i need the hasport harness? or can i just use the whole integra harness?
You cannot use the Integra harness as is.
Go to Yahoo and search on ZC Engine swap. I guarantee like 1345642176786425767236487 posts on this one topic.
I think the original came out of HondaTuning, or Super Street, and everyone wanted it on their site...
All these articles seem to be worded the same, although there are different authors.
Also, pay attention to the pictures. Seems that they are all the same too.
I donno. Plaigarism?
Scott
Scott
theres at least one guy on this board, too, that sells adapters to go from OBD0 to OBD1..
I bet if you post in the 'Tech' forum a topic like: going OBD0 to OBD1 he will post and help you out.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nysikcrx »</TD></TR><TR><TD CLASS="quote">ok listen guys i bought the b-series mounts off ebay and thinking bout getting the harness but...here's the deal my friend crashed his integra the whole bak got smashed in so he giving it to me its a 92 gs integra wit the ls motor in it i kno this is obd1 and my car obd0.the whole front clip is there so wat do i need to take off to do the swap and do i need to buy a harness conversion? cant i just use the nice uncut harness in the integra? and about shifter linkage how long do i have to cut the stock one to fit the crx? and is it worth it? or should i buy the hasport one? need info guys doing swap sat mourning......if anybody did one and kno about problems i'm gonna run into email me nysikcrx@aol.com or reply thanks guys
If i was u i would use the engine harness from the teg back to th ecu and call it day there. Since you have the entire integra front clip the only parts you wil need are the HASPORT mounts.
The only hard labor you will have to do is the beating in on the frame rail, and rear engine beam.
FYI i drive a B18A1 SM civic SI that i did all the work my self(please remember no swap are easy just some are less painless).
</TD></TR></TABLE>If i was u i would use the engine harness from the teg back to th ecu and call it day there. Since you have the entire integra front clip the only parts you wil need are the HASPORT mounts.
You will need an OBD0-OBD1 adapter harness. You need to repin the distributor plug to accept the OBD1 distributor, add 2 injector wires, add 2 wires for the CYL position sensor to the new Distributor, add the Jumper plug for the 4 injectors, 1 power wire for the heated O2 and then over to where they get power from the 2 YL/Black wires. Add three a total of 3 wires to the 4 wire O2 sensor. If you need a converter and modified DX-OBD1 LS harness let me know. Easier to go this route and modify your DX harness than redo whole car unless you have boatloads of time to throw away. Always use what harness came in the car and add what you need to it to make the swap work, alot less headaches later on. If you are intested then you could send me the DX harness, the LS harness, the DX ecu, the LS ecu plugs and it would make it a little bit cheaper. I sell alot of OBD0-OBD1 adapters as well.
Modified by Caleb V at 7:38 AM 10/13/2003
stuff off the integra, engine, tranny, intermediate shaft, axles, integra harness for mpfi plugs, shiftlinkage with stiff rod, vaccum parts, throttle cable, clutch cable. why not jsut keep the teg there utnil you finish the swap and youd make sure you got everything there because thats the easiest. because you know we will forget to tell you a part so its best just to keep the whole car there utnil your done with it.
oh and for the obd0 to obd1 i think its blown90hatch taht sells them on here
preetyboi06
Jul 17, 2009 09:57 AM
bradykiller
Jun 24, 2005 06:52 PM
Eighty8Crx
May 7, 2005 03:33 PM
