ef civic rear rebar
Re: ef civic rear rebar
im assuming the OP means bumper support.
theres 4 nuts you need to remove on the back wall. 2 of them are inside the car near the bottom of the spare tire well, 2 of them are outside the car just under the spare tire well.
if the bumper is still attached, then remove the screws on the edge of the bumper on the rear wheel well, then the whole support and bumper remove together.
dont bother to remove the large, thin fender washer bolts that have phillips head screwdriver, with an actual screwdriver.
it WILL strip.
use a vise grip to grab the edge and twist it off. best tool to use is the knipex cobra pliers.
it WILL strip.
habanerored06si
10
10-17-2012 08:03 PM
Arthas
14
10-02-2010 01:25 PM
beedoublejay
09-18-2005 02:48 PM
