code 9 on ZC still...
Old Jan 22, 2002 | 07:04 PM
Cereal_Killer's Avatar
Default code 9 on ZC still...
well went to the junkyard today and found a 88 teg cyp sensor. as that is what my car has been throwing a code for for the past week. came homme let the car cool, swapped it out with the new (used) one, unplugged the ecu and reset under the hood. plugged everything back in and still the darn code comes up, it comes up as soon as the car is started. as suggested before i checked the wiring, turns out ok. i swapped the 2 wires for the sensor from where they were connected before, and it idles a bit better but after about a min or 2 the code comes back up (doesn't come up as soon as it's started). so not sure which way it needs to be wired as the code comes up either way. and "reparitions" said it shouldn't come up if i have it wired the right way.
so my only guess is the distributor as "rep" has said. or is ther something else i am missing?
Old Jan 22, 2002 | 07:18 PM
vsual's Avatar
Default Re: code 9 on ZC still... (91efzc)
try looking at the ecu side. loose pins on the ecu can cause this. i was throwing code #4 which was the crank position sensor for a whole 3 weeks. i've rechecked everything and purchased me a brand new distributor and still gave me code#4. til i found this site and met blown90hatch...he stated make sure all your connections are good. i found out the next following morning....it was a loose connection on the ecu side. damn it took me 3 weeks to get rid of code#4. hope this helps. good luck
[Modified by vsual, 4:21 AM 1/23/2002]
Old Jan 22, 2002 | 07:24 PM
CimorelliCRX's Avatar
Default Re: code 9 on ZC still... (vsual)
i had this problem on my crx, it was b15 pin, i didnt put it in allt he way, vsual is the one who told me to fix it, listen to him, hes probably right.
Old Jan 23, 2002 | 04:58 AM
Default Re: code 9 on ZC still... (CimorelliCRX)
all my pins are fine believe my i've checked them many times. i've ehad my ecu disconnected about 3-4 times just this week and there are no pins sticking out that are obvious. but thansk anyway...
superslowcrx91
Sep 30, 2013 12:54 PM
Prelude MIke
Apr 22, 2004 07:34 PM
EF'n
Aug 20, 2002 01:11 PM
White Lightnin
Jun 28, 2002 09:15 AM
Cereal_Killer
Jan 25, 2002 01:52 PM
